My Car Just Backfired Really Bad
Old Jan 23, 2008 | 04:55 PM
my bandit's Avatar
Default My Car Just Backfired Really Bad
i started my car today and i reved it to about 3000 rpms and it backfired really bad, smoke came out and it smelled really bad. i just pressure washed my engine on monday and it was fine until i started it up today. i have drove it since i washed it about 4 times for about 30 minutes each and nothing happened. can anyone tell me whats wrong
Old Jan 23, 2008 | 04:57 PM
GrahamHill's Avatar
Backfire or popped? A backfire is when the charge comes backwards through the intake and throttle body. If its in the tailpipe its a pop like unspent fuel. Did it pop any more after it warmed up?
Old Jan 23, 2008 | 05:05 PM
my bandit's Avatar
it popped my bad
after it did i shut off the car and did it again but not as bad
Old Jan 23, 2008 | 05:28 PM
Zero4488's Avatar
Restricted User
Hmm....is the car running rough?
Old Jan 23, 2008 | 07:59 PM
my bandit's Avatar
no its running perfectly fine
smoke is coming out of the exhaust though and i live in florida and its not cold right now
Old Jan 23, 2008 | 09:53 PM
Soul TKR's Avatar
hmmm.... check your oil real quick and see if it's discolored, or has any water in it, or anything out of the ordinary... if it looks ok your probably fine... how many miles you got on your car?
Old Jan 23, 2008 | 10:33 PM
00Formula00's Avatar
What was the engine temp?
Old Jan 24, 2008 | 12:58 AM
GrahamHill's Avatar
Make sure your plug wires are still on
Old Jan 24, 2008 | 01:12 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
^ +1, plug wires and plugs. Check odd things like the crank sensor.
Old Jan 24, 2008 | 01:47 AM
GrahamHill's Avatar
or maf sensor plug
Old Jan 24, 2008 | 02:20 PM
my bandit's Avatar
just changed the oil about a month ago.
113000
i had just started it up so the lowest notch on the gage
Old Jan 24, 2008 | 03:41 PM
Asmodeus's Avatar
ignore it unless it happens again
Old Jan 24, 2008 | 04:18 PM
my bandit's Avatar
thats what ive been doing i just wanted to know why it did it bc it scared me .
i feel that my car is just falling apart, its squeaking and ive replaced all of the belts and pullys and when it shifts i hear a squeak in the rearend so i just dont want more things to go wrong
Old Jan 24, 2008 | 05:27 PM
blownws6_nc's Avatar
coil packs could've got wet, just a thought!
Old Jan 24, 2008 | 05:29 PM
my bandit's Avatar
the backfire or squeak
RedRocketZ28's Avatar
If you just started and the engine was cold don't worry about it. My LT1 used to pop really loud when the engine was cold and I got on it a bit.
Old Jan 24, 2008 | 05:38 PM
my bandit's Avatar
but would a cloud of smoke come out?
Old Jan 24, 2008 | 05:40 PM
the backfire, if a little moisture gets in the pack it will pop. I would'nt worry 2 much about it as long as it don't do it again.
Old Jan 24, 2008 | 05:42 PM
my bad, I just seen where you said you have drove it since u washed the engine. hmm. don't know.
Old Jan 24, 2008 | 05:43 PM
my bandit's Avatar
i had used degreaser and sprayed it down like 2 days before but it was running fine and i had gotten on it after i sprayed it down and nothing happened
