spohn solid mounts - cracked block?
Old Jan 30, 2008 | 03:43 PM
'99bluez's Avatar
Default spohn solid mounts - cracked block?
First off I have done a search, and read a lot on this subject. Yes I know there will be vibration and taking out the clutch will be a little extra work. I really like the idea of shaving of 20lbs by using spohn solid motor mounts, nevermind the extra $$. I read through all the speculation from all the people who are hating on the solids. What I want to know is does anyone have any proof, or have ever seen a motor get damaged from solid mounts. I don't want people saying "oo yea i heard that could happen" I want actual proof. Please only reply if you have first hand knowledge. Thanks!
Old Jan 30, 2008 | 08:54 PM
Whitez406's Avatar
Ive used solids before and i love them. I cant wait to use a set in my 00. I just checked the bolts every now and then and i never had any problems at all.
Top Fuel's Avatar
I have first hand knowledge that my block isnt cracked and I've been running them for 2 years. I didnt weigh them vs. the factory but it didnt seem like a 20lb difference, maybe 10
Old Jan 30, 2008 | 09:14 PM
Ls1Gummi's Avatar
All i heard was all bad stuff. But i would like to run solids 2
Old Jan 30, 2008 | 10:38 PM
arcticwhiteTA's Avatar
I have been running the spohn solids for about 4-5 months now and have had no ill effects. I'm making mostly stock power but I've had them through most of a MI winter with the cold-hot cycles and the block is still good.
Old Jan 30, 2008 | 10:56 PM
J_Z28_T's Avatar
Default ??
how much are the spohn motor mounts, i was going to get the pa racing solid mounts and there like $30 bucks
Old Jan 30, 2008 | 11:33 PM
'99bluez's Avatar
$145 wow! those PA ones are a cheap price. But there is no pic on their site.
Old Jan 30, 2008 | 11:41 PM
TheSilverOne's Avatar
i've had spohn solids for a year and no problems here
Old Jan 31, 2008 | 05:50 AM
bigfatls6's Avatar
Whats the benifit to running the solid mounts other than weight? Do the factory mounts break a lot or what? If you making basicly close to stock horse power whats the benifit?
I have a 69 nova also and it makes close to 700 hp na and 1000 on nos. I ran solid mounts on it and kept twisting the mounts and breaking them. I switched to motor plates now.
Old Jan 31, 2008 | 09:30 AM
warp10's Avatar
Been running mine for about 6 months on a daily driver and not problems at all.
Old Jan 31, 2008 | 09:35 AM
Coy's Avatar
Coy
I daily drove my last Trans Am with spohn solids on some horrible streets (potholes and such) that gave some serious jolts and never had any issues.
When I need mounts for my Firehawk I will use the spohn solids again.
Old Jan 31, 2008 | 11:23 AM
to avoid y pipe banging when we install headers
