Using GM high lip pulley on F-body LS1
Old 02-02-2008 | 07:31 PM
jimmyblue's Avatar
Moderator
Default Using GM high lip pulley on F-body LS1
I got a part number which turned out to be the entire
tensioner assembly, see pic.
The tensioner assembly is not a direct fit, its "feet"
are too short. So I swapped the pulley onto the old
tensioner base. My old pulley bearing had a lot of
play, for being under 30K miles. New one is tight.
New bearing says Made In China. Makes you proud
to buy American.
I had to grind some casting flash off the "head" casting
to eliminate interference on the inside, and I had to
sand about 1mm off the rear lip face to get it not to
drag (much) on the body too. I followed up with some
more sanding in place with the motor running until it
did not chirp anymore. The thermoplastic doesn't like
high speed sanding much, it made a lot of stringers
that I had to peel off and scuff back.
It's on there now, looks stock, spins quiet.
I would recommend against this project since you can
find (in fact hard to miss) people selling high lip aluminum
pulleys for less than I paid, since I bought a useless base
along with the pulley I wanted. There is no GM number
on the pulley itself. Anyway it was sunk cost so I finished
it.
Old 02-04-2008 | 11:57 AM
TLewis4095's Avatar
We have them in stock ready to ship:
$49.95 $10 S&H flat rate in the lower 48.
813-628-0080 to order or paypal: Sales@RevXtreme.com
Old 02-05-2008 | 06:02 PM
405HP_Z06's Avatar
Can you Type III hard coat anodize this? What is the additional cost?
