Spark plugs??
Old Feb 6, 2008 | 02:18 AM
slowjoe99's Avatar
Question Spark plugs??
We have started working on my new setup and while the engine is going to be out I want to go ahead and replace the spark plugs. I didn't know if I should replace them with stock ones or another kind or brand. Here is what my set up is going to be:
MS3 cam (237/242 .603/.609")
CNC ported LS6 heads
LS6 intake w/ ported TB
Old Feb 6, 2008 | 03:33 AM
somws6bird's Avatar
You should probably go with NGK TR-55
and if you going to spray at all the TR-6's
Old Feb 6, 2008 | 05:58 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
You can also run the TR6s without problems. Since you are adding close to a 100+ hp they won't hurt anytthing. I ran them with my H/C package before I sprayed my car
Old Feb 6, 2008 | 08:19 AM
RareBreed0295's Avatar
Old Feb 6, 2008 | 07:27 PM
seawolf18's Avatar
+1 for the TR6 plugs. This is what I run in my heads/cam setup.
Old Feb 6, 2008 | 08:02 PM
hammerdown2000's Avatar
NGK TR55s work like a charm! +1
Old Feb 6, 2008 | 08:54 PM
jcvett56's Avatar
TR-55 is the way to go....
Old Feb 7, 2008 | 02:13 AM
slowjoe99's Avatar
haha anymore opinions??
By the way I don't plan on spraying... I'm N/A all the way!! ...probably
Old Feb 7, 2008 | 06:30 PM
blkbird's Avatar
Im using TR55s on my car. No problems......
Old Feb 8, 2008 | 01:41 AM
slowjoe99's Avatar
what is the difference between the 55s and the 6s anyway. the 6s are for more power or spray? and the 55s are for naturally aspirated motors??
Old Feb 9, 2008 | 06:41 PM
Matt D's Avatar
Retired Street Racer
For a heads and cam car, you would want to go with a TR6 due to more horsepower than stock.
Old Feb 9, 2008 | 07:00 PM
Camaro_SS's Avatar
Both run colder than stock plugs. 6's work very well in boosted applications because of the higher compression that's seen (no flameouts). 55's are a step down in cold range.
Old Feb 9, 2008 | 07:01 PM
Disturbed Bird's Avatar
the tr6 is one step colder plug than the tr55.
either will be alright but the tr6 you will need to gap to .035
