Lsx 90 Mm Help!!
Old Feb 7, 2008 | 09:05 PM
METAL MANIAC's Avatar
Default Lsx 90 Mm Help!!
HI GUYS,
I GOT MY 90MM FAST INTAKE AND THROTTLE BODY TODAY AND AFTER READING THE INSTRUCTIONS. I DISCOVERED THAT I NEED THE LS6 COOLANT HOSE AND PLUGS..I KNOW I DID NOT RESEARCH! BUT HERE IS THE DEAL IF AT ALL POSSIBLE I NEED TO GET THIS PROJECT DONE THIS WEEKEND
IS THERE ANY WAY TO GET AROUND THIS...ANY OTHER MODIFICATION! PLEASE HELP A BRO OUT IF YOU HAVE ANY IDEAS PLEASE.....THANKS!!
Old Feb 7, 2008 | 11:19 PM
00bluews6's Avatar
Default Good Start
i just got done doing the same thing to my car this link helped out alot
http://www.ls1howto.com/index.php?article=18
00bluews6's Avatar
what year is your car
Old Feb 7, 2008 | 11:26 PM
00bluews6's Avatar
by the way you can get all the stuff you need at the local hardware store or o'reillys let me no if you have any ?? pm me
Old Feb 7, 2008 | 11:31 PM
00bluews6's Avatar
the crossover and plugs you can get at any gm dealership
Old Feb 8, 2008 | 12:21 AM
bigdsz's Avatar
Instead of plugging the rear steam vents I kept them functional by afro engineering my old LS1 coolant lines with a tee and some fuel line. Now I get great flow from the rear steam vents. I wa surprising how much air was trapped in the back of the heads. I have always suspected hot spots in the back of the heads might contribute to # 7 frequently getting nuked.
Old Feb 8, 2008 | 02:26 AM
jermzz's Avatar
Thats the best way to do it. It's not pretty, but it's effective.
Old Feb 8, 2008 | 10:35 AM
bigdsz's Avatar
Actually it looks pretty good. I have a tee in the back between the steam vents and then have a 5/16 ID fuel line running between the intake and the valve cover forward and it is covered by the PVC line. Up front I have another tee that connects with the front steam line that goes to the radiator.
