burn a valve with no backpressure?
when I last posted I was concerned about floating a valve, Now I'm worried about burning a valve I have side exit no muffs no cats. Is it possible?
I've never hert a valve by running open headers. The only way I know you could hert the valves is maybe by open shorties or manifold. The valves get warped if cold air comes back in the head when you have no back pressure but with open headers cold air can not go past the collector. You should have no problem.
