TSP Duals out the back?
Old Feb 20, 2008 | 10:48 AM
chevyhighrider's Avatar
Arrow TSP Duals out the back?
Has anyone ever ran the Texas Speed X-pipe true dual system, but instead of turndowns right after the bullets continued the exhaust to the bumper? If so could post up some pics/sounds thanks.
Old Feb 20, 2008 | 10:49 AM
LS1-NAVY's Avatar
i would also like to c this
Old Feb 20, 2008 | 10:54 AM
Or Headers to X-Pipe to Bullets and then out the back. My old car had the turndows which I liked the sound of, but pipes to the bumper would look cleaner and would be better as long as the sound stayed somewhat the same.
Old Feb 20, 2008 | 11:43 AM
DirtyJohn's Avatar
I had it done.
Click the picture for more pix
Ordered parts and had a buddy do the welding and putting it together.
Parts:
  • High flow metallic spun Carsound 3" cats part # ???
  • TSP Kit With 18" Dynomax bullets chopped.
  • 7 x 3" Mandrel bent U bends from Jegs
  • 2 x 18" Flowtech redhot bullets from Summit
  • 2 x 3"-2.5" turndowns from Jegs
  • 6 x 3 bolt flanges
Old Feb 20, 2008 | 12:08 PM
kyles2000z's Avatar
wow thats alot goin on there...2 cats, 4 mufflers, bet taht things weighs a TON!!!
Old Feb 20, 2008 | 12:22 PM
DirtyJohn's Avatar
Meh, I eat light.
Old Feb 20, 2008 | 12:30 PM
tylerdj's Avatar
It's been done many times....in fact I'm having mine done this weekend....I'll post up pics after I get it done though.
Here are some pictures from a local guys car ('02 double U S-6) who had his TSP duals ran out the back.
Old Feb 20, 2008 | 12:53 PM
SSNISTR's Avatar
Yeah, I'll pass!
Old Feb 21, 2008 | 04:35 PM
Sweet, thanks alot those look pretty good. How does it sound though, I know with mine the turndowns gave it a sweet deep bassy sound but there was also a kinda gay hissing noise as well. The hissing was most noticeable from outside the car at low to mid rpms with a higher load on the engine. I think that it looks much better all the way to the bumper though.
Old Feb 21, 2008 | 04:41 PM
tylerdj's Avatar
If I get mine done this weekend, I'll post up some pics and let you know how it sounds.
Old Feb 21, 2008 | 09:07 PM
Delaware ss's Avatar
DirtyJohn- is that all 3"? have any problems with the wires onn driver side over the axle?
Old Feb 21, 2008 | 09:21 PM
speed_demon24's Avatar
http://s86.photobucket.com/albums/k1...xhaust%20pics/
Cat's cleaned up the sound alot too, it's deeper and cleaner sounding than before. I'm running spiral flows FWIW, cats are magnaflow 59959's.
Old Feb 22, 2008 | 08:11 AM
DirtyJohn's Avatar
Nope, right after the 3" bullets it goes to some 2.5" reducers, then over the axle with 2.5" and out.
The wiring harness was a big effort for the guy that did the install.
He literally drilled out the white connector from the sheet metal, then he individually stripped and soldered 12" extensions on each of the wires to pull that box away from the body.
I guess he even found the right gauge color coded wire for each one too, he was proud of that bit. Tied it up somewhere around the diff box with some zip ties.
He said it would be impossible to route the pipe through that area without pulling that harness. If your trying to find a shop to do it, or want to make the job easier for yourself, that could be something you could tackle yourself. If your handy with wires and a soldering iron...and a drill...and heat wrap..
