A lot of people remove this brace, is that ok??
Old Feb 23, 2008 | 03:33 PM
m_ghonim's Avatar
what's the DSL?
Old Feb 23, 2008 | 03:41 PM
99FormulaM6's Avatar
drive shaft loop...
Old Feb 23, 2008 | 03:45 PM
bene's Avatar
Trunion King
Don't remove it! Your car will completely act normal. J/K. I removed mine.
Old Feb 23, 2008 | 04:13 PM
00transamnh's Avatar
Originally Posted by JScamaro
When I did my header and y pipe install that brace didn't fit back over the new exhaust.
same...
Old Feb 23, 2008 | 06:13 PM
Dskeet6's Avatar
this could help keep the metal from fatiguing in the tunnel section of the car overtime???? the more metal bends the more fatigued it gets.... just a thought
Old Feb 23, 2008 | 06:19 PM
candidate zero's Avatar
I took mine off when I did my exhaust.
Old Feb 23, 2008 | 06:31 PM
Hilton's Avatar
Tough Mudder
Heh, so anyone want to buy that driveshaft loop I can't use anymore? It's red, so you know it's fast!
Old Feb 23, 2008 | 07:52 PM
BlackDuk98's Avatar
I was a little paranoid about driveing w/out it to. I don't see a problem if you don't have it. It is so crappy in the first place I don't think it does much good. Plus, I got a tunnel mount torque arm which solves the problem of not haveing that tunnel brace. Plus I read a bunch of stories of having the torque arm cracking the trany tail housing, I just went with the tunnel one.
Old Feb 23, 2008 | 08:30 PM
bottlefed98's Avatar
wouldnt go back after the ypipe & headers here either
Old Feb 23, 2008 | 08:56 PM
INMY01TA's Avatar
Huh??
Old Feb 24, 2008 | 10:42 AM
Lt1Porsche's Avatar
I just removed mine yesterday because of my TSP true dual setup. But ive been in the automotive repair industry for a long time and I took one second looking at it and removed it without a second thought at all. It is not needed and will not ruin to structural integrity of the car at all. Just take that POS off and get your exhaust installed. PERIOD.
Old Feb 24, 2008 | 10:46 AM
  #32
TXZ28LS1's Avatar
i dont have one either!! been driving it without one for awhile now!!
Old Feb 24, 2008 | 12:00 PM
  #33
santiago's Avatar
Originally Posted by NHRAMAN
THAT IS A STUPID STATEMENT FOR MOST PEOPLE. SEE: Race Forum.
why is it stupid its just common sense. if you need something leave it on if its not a nescessity take it off. its simple
Old Feb 24, 2008 | 12:23 PM
  #34
Castratikon's Avatar
If you want it and you can't clear the exhaust, put some spacers in there with longer bolts. I did that when I had a V6 and I changed the exhaust and I'm going to do it on the WS6 once it gets warm enough for me to put the true duals on it. If there wasn't a purpose for it, it wouldn't be on the car. Who knows whether that purpose is stupid or justified in this case, but when it's easy to keep, I don't see a point in chucking it unless you have no ground clearance with it with spacers installed.
Old Feb 24, 2008 | 12:47 PM
  #35
Demonicbird00's Avatar
mines been gone for 3 yrs now
-brandon
Old Feb 24, 2008 | 09:17 PM
  #36
The Alchemist's Avatar
UNDER PRESSURE MOD
I really don't think it does much. You can actually twist it by hand, it's that flimsy.
Old Feb 24, 2008 | 09:23 PM
  #37
bene's Avatar
Trunion King
Is that UMI unit you are using?
Old Feb 24, 2008 | 09:30 PM
  #38
BlackDuk98's Avatar
Yes, thats a UMI torque arm.
Old Feb 24, 2008 | 11:00 PM
  #39
BigDaddyBry's Avatar
I took mine off 2 years ago, no difference whatsoever.
If you are concerned, I'm local to you and I have this tunnel brace from BMR, but its in red and scraped up some:
It gives a few more inches of clearance for the exhaust, but also limits your ground clearance.
Old Feb 24, 2008 | 11:12 PM
  #40
Jakester136's Avatar
DONT REMOVE IT YOU WILL THROW A CODE!!! LOL j/k ...If you need to remove it to tuck in your exhaust a little closer for better clearance or what not it will be fine. I removed mine.... However make sure you have plenty of braces to keep everything nice and tight. Other than that you'll be just fine without it.
