Need help with sputtering car after racing
First time racing on drag radials(hoosiers),first time on heads,cam,and moser,basically a virgin at the track.
1st run- Not enough burnout- 2.0 or 2.1 60 foot( Yuck). Ran good after the launch though.Ended up with a 12.2 @ 119.47mph
2ND RUN- Not enough burnout again(amatuer) 2.0 60 foot..Ran strong to get a 12.2 @119.xx
3rd run -Heated them up much better,lowered tire pressure to 15 lbs,and launched at around 3500-4000rpm. That felt much better and netted a 1.88 60 foot but half way down the track my check gages light flickers and car starts sputtering.I noticed before the run that the car was a little hesitant to start.So after sputtering across the line 18 seconds later@ 56mph I pulled back into the lanes.I tought I would give it another try to see if it would do it again.
I go to get in the car 10 minutes later and it wont start,the battery was dead.So, push it out of the line and push start it.I then let it idle for 10 minutes and drove around the track for 10 more minutes to charge the battery
4TH run- Same as before, except on launch which was a 1.8 again, my check engine light comes on and sputters even worse down the track.I didn't think it was going to make it.
That was it for me for the night.
I took the battery in for a test today which took a fricken hour and he comes back and says "it's marginally ok, but I'll replace it anyways".
Now off to Auto zone to get my SES code read because I don't have the technology yet. Light is off by now and no codes are stored they say.
I get a fuel filter and replace it to rule that out. The car is still falling flat on it's face after 1/2 throttle, and I got a new SES just now while it was sputtering.I just finished changing out the plugs to some fresh TR55's and it's still doing it.Also just checked fuel pressure and it seems good.It's @ 60psi at idle and when I gas it up by hand.
I'm running out of ideas. o2 sensors maybe.Only have two, the rears are tuned out.Maybe injecters??How do you check them.
Thanks
Jay
Sounds to me like you have a charging system problem, since your battery was dead, it also makes sense, because The higher you rem, the more voltage you need to go to the coils, which sends spark to the spark plugs, which ignites the fuel, etc etc. I had this same very thing happen to me, come to find out, it was the alternator. Get it checked out, let us know what happens, keep an eye on your voltage meter.
They had one so I bought it thinking I had one at home. Have to run out and get another. I can't see how both went out at the same time though.Thinking this may not fix it. Still leaning towards a fuel pump or charging.
This kinda stuff doesn't happen everytime you race does it?
Here goes day 2.
Changed out my o2 sensors
Removed the old alternator so I could go get it checked out. Discount says it's shot, bad diode. I head to pepboys because it's still under warranty there. Go home and put my stock alt pulley back on ( forget about underdriving the alt anymore) and corresponding new belt.
So at this point I have new battery,o2's,fuel filter,tr55's and alternator.
Test drive sucks. Barely made it around the block spitting and sputtering, everything but stalling, but the volt meter is better then ever. Reading 13+volts.
Back to the driveway.
Just getting ready to research new fuel pumps (even though the two times I checked it it read 50+ psi) and I decide to check the first thing I should have; the air filter. I have a whisper lid, maybe one of the first 10 made in 98, so it's a bit worn. You know how they tell you to weatherstrip the inside lip? Well you won't fricken believe this!!!! A piece of my weathersripping was dangling about 8 inches long through my descreened MAF and near my TB. Instantly figured that was the whole problem.Put everything back together minus the weatherstripping and went for test drive no# 34 . This time volts are perfect,no lights are on and what do you know. It runs like a raped ape. I figured I would head to my favourite side street for a real 1/8 mile test run. Launch it, shift light comes on, wind out second, to redline and letoff. Just then my CHECK GAUGES light comes on and volts go down to the red about 10.5 volts.If I rev to 3900 the light goes out, anything less and the light comes back. Volt meter stays in the red the whole time. I think I just killed my "new" remanufactured in mexico alternator.
It ran perfect until I redlined it.
Jay
