ls6 intake cleaning??
Old Feb 24, 2008 | 08:57 PM
bigti99a's Avatar
Default ls6 intake cleaning??
well i am getting my lists together and arranging the parts i already have. i am on the fence about painting my ls6 intake manifold. i want to clean it real good at a minimum, possibly paint it. what methods have people used to clean it real well in all the little nooks and crannies, inside and out?? Do i have to scuff it at all before painting or just get paint that will bond to plastic? thanks.
Old Feb 24, 2008 | 09:53 PM
socmguy's Avatar
Restricted User
Just clean it w/ some simple green. tape it off, prime it, and paint it.
Old Feb 24, 2008 | 10:19 PM
bww3588's Avatar
i threw mine in the bath tub, cleaned it inside and out. ofcourse, i let it sit for a week or so to make sure it was dry inside, but that seemed to work. got all the dirt off it.
to paint it, i took a scotch brite pad and scuffed it up real good, then blew it off with an air gun, and painted it with Krylon Fusion. **** worked perfectly.
Old Feb 24, 2008 | 10:54 PM
SweeTbone's Avatar
Use the Simple Green as stated. When it pools up in the crannies just blow it out with compressed air. You don't really need to scuff it, but most people sand the casting marks down and the texture down to give it the "smooth" look. If you really don't want to do that, it's okay. Just spray some adhesive promoter on, then use regular rattle can. I've read not to use the rattle can spray that is made for plastics. Also, before you spray, Dupli-Color makes this little Prep Wipe thing for like 99 cents. Wipe down all the grease and any cleaning residue off with it, then spray. My write up. --->
http://www.geocities.com/mrmtransam/intake/
Old Feb 25, 2008 | 12:58 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Clean anything under the hood with simple green. That stuff is a wonder maker!
Old Feb 25, 2008 | 08:33 PM
bigti99a's Avatar
thanks fellers. its not a show car and i dd it so the intake gets some road grime on it thats kinda why i may not paint it. any color suggestions for a maroon metalic z? i was thinking just a glossy black. all my umi **** is black so it would kinda flow ok color wise. time to go get some simple green and start scrubbin!
Old Feb 25, 2008 | 08:34 PM
bigti99a's Avatar
also do you think throwing a catch can on there at time of install is a good idear?
Old Feb 25, 2008 | 10:50 PM
bww3588's Avatar
probably a good idea,
Sweetbone, i used the Krylon Fusion twice when i painted my intake, and it hasent came off yet. now its got battery acid all over it from the wreck, but it still hasent pealed or anything.
Old Feb 26, 2008 | 07:54 PM
bigti99a's Avatar
should i worry about getting anything in that rear vac out L shaped thing? dont know what its called sorry.
Old Feb 26, 2008 | 08:39 PM
bww3588's Avatar
just take the MAP sensor out of it before you clean it,
Old Feb 26, 2008 | 09:48 PM
bigti99a's Avatar
does it twist out or pull? i see the white dot that lines up. i dont want to break it? sorry i keep drawing this out. i want to do it right the 1st time.
Old Feb 26, 2008 | 10:27 PM
bww3588's Avatar
kinda twist it, and pull up. its held in by a little rubber stepped washer looking thing. jsut make sure when you put it back in, it lines up with the tab. other than that, all the 90* elbow is is a peice of pipe. clean that sucker out good.
Old Feb 26, 2008 | 10:51 PM
SweeTbone's Avatar
Yeah, I was just going what I have read on the internet and this board. I have no first hand experience with the Fusion stuff whatsoever, so if it worked for you, it will probably work for this guy.
Old Feb 26, 2008 | 10:54 PM
bigti99a's Avatar
WHAT THE HELL IS IT ME OR IS THIS THING JUST REALLY IN THERE. i think the sensor is already out. i see the small hole and clip on top of the elbow coming out the back. just trying to verify that the elbow is part of the intake and not to continue to pull on it. or does the elbow going into the half dollar sized hole in the back actually come out? and i thought i was out of the newb stage!!
Old Feb 26, 2008 | 11:02 PM
kwiksilverz28's Avatar
Pay someone like me to paint your intake. Yummy! Filled and painted LS6....and with my custom hidden LED's for the night shows!
Old Feb 26, 2008 | 11:06 PM
bww3588's Avatar
you got the sensor out, the peice your talking about doesnt come out. the sensor is about the size of a mini bic cig lighter and it fits in that little hole.
Old Feb 26, 2008 | 11:27 PM
bigti99a's Avatar
i figured. thanks. very very nice work kwik. a little overkill for me. but i am sure that gets plenty of looks, and if this was a show car it would be different. very nice ride though.
Old Jul 7, 2008 | 07:44 PM
DanWS6's Avatar
That looks cool!
