Harmonic balancer question
Old Feb 27, 2008 | 06:22 AM
Mike Cordero's Avatar
Default Harmonic balancer question
Do the harmonic balancer in a LS1 and LS6 is the same? Can I use a Corvette LS6 balancer im My Camaro during a swap? It will match my accesories? Sorry for my ignorance. Thanks.
Old Feb 27, 2008 | 07:08 AM
brad8266's Avatar
Theyre the same.
Old Feb 27, 2008 | 07:21 AM
BlackScreaminMachine's Avatar
Internet Mechanic
The arrangement is different but the balance is the same
Old Feb 27, 2008 | 08:06 AM
Default balancer
So if I'm going to use a LS6 block in a Camaro, I must use a LS1 balancer instead of a LS6 one?
Old Feb 27, 2008 | 08:23 AM
1Topgun's Avatar
The Corvette crank pulley and front accessory pullies fit 0.40" closer to the block than the Camaro/Firebird pullies, according to GMPP LS1 swap guide.
-Mike
Old Feb 27, 2008 | 08:35 AM
Internet Mechanic
The balance is the same, the accssories are arranged differently to accomondate the vette engine bay but the balance is in the same place and is the same size.
Old Feb 27, 2008 | 11:13 AM
1Topgun's Avatar
LS-type engines are internally balanced, so the crankshaft pulley is not engine-specific. However, the Corvette crank pulley has a different "offset" than the F-body crank pulley, of 0.40" difference, which locates the belts closer to the block on the 'Vette.
Old Feb 27, 2008 | 12:10 PM
This is good. I'm learning a lot from all of you, but I think this is the more especific answer. Thanks.
