Possible to install flywheels backwards?
Old Mar 1, 2008 | 03:21 PM
Datsun350Z's Avatar
Default Possible to install flywheels backwards?
Is it?
Old Mar 1, 2008 | 04:27 PM
SladeX's Avatar
The LS1 flywheels... maybe, though I think it's marked. For LS2 flywheels, no.
Old Mar 1, 2008 | 04:51 PM
ls1leadfoot's Avatar
isnt it bowed or "concave" towards the crenk.....mine would only fit one way....or else the bolts are not long enough....
o well.....good luck and let us know
Old Mar 1, 2008 | 05:24 PM
Datsun350Z's Avatar
Mine looks like this as of right now. The clutch surface is on the side with the clutch and the backside looks like it hasnt been machined. This is the only way I would think that the flywheel should go on.. so.. the starter is about 3/4" away from where it should be. Its pulled back that far..
Old Mar 1, 2008 | 05:38 PM
Datsun350Z's Avatar
GTO starter
LS1 Starter
Old Mar 1, 2008 | 06:42 PM
raven154's Avatar
Should your pressure plate bolts be sticking out that far? Something doesn't look right but I have a different setup than you so I cant say for sure.
Old Mar 1, 2008 | 06:54 PM
Datsun350Z's Avatar
Those are temporary bolts holding that on just to have stuff bolted up.
Old Mar 1, 2008 | 07:03 PM
THEBRAD's Avatar
its on right
Old Mar 1, 2008 | 09:01 PM
Datsun350Z's Avatar
HAH!
Figured out that problem.
Didnt know that there was a flexplate adapter on the end of the crank! Came stock on the Chevy truck that the engine came out of. Had no clue it was on there until I accidentally put a bolt in the wrong hole and it pushed the adapter off a small amount.
Hopefully this could help someone a whole lot later on.
Old Mar 2, 2008 | 12:49 AM
THEBRAD's Avatar
oh i thought u meant u had it turned around backwards. sorry, i was no help
Old Mar 2, 2008 | 04:24 AM
Datsun350Z's Avatar
This is what I was talking about.
Old Mar 2, 2008 | 06:09 AM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
A question better than "is it possible?" would be "why would you want to?"
Old Mar 2, 2008 | 12:02 PM
Datsun350Z's Avatar
I just couldnt figured out any other reason at all.. that the flywheel that is the same for an LS1 LS2 5.3 4.8 and 6.0 was not lining up with my starter... Just was considering all options at the time, because I was about to go nuts.
