do these really work?
Old Mar 4, 2008 | 01:18 AM
SYon22s's Avatar
Default do these really work?
http://www.jegs.com/i/VaraRam/937/VR-3/10002/-1
any of you guys have one? is it worth the money?
Old Mar 4, 2008 | 01:21 AM
stefan256's Avatar
looks alot like the smooth bellow from slp i would say its no where near $50 worth, when you can make your own for $5- ill look for that thread and show you
Old Mar 4, 2008 | 02:09 AM
Last C5's Avatar
I have one on my C5 Vert.
Probably not.
It didn't hurt anything. But, I can't say it really helped anything either.
Old Mar 4, 2008 | 06:20 AM
night ryder's Avatar
waste of money.
Old Mar 4, 2008 | 09:18 AM
teke184's Avatar
its totally different than the bellows.
this goes INSIDE the TB....doesn't enlarge it at all...just smooths out the transition into the thottle body bore.
don't see how it could help really.
$$ better spent on a ported TB
Old Mar 4, 2008 | 09:24 AM
snake charmer's Avatar
looks like something i saw in the plumbing section of lowes . they got some other cool ones for alll for under $10 .
Old Mar 4, 2008 | 11:47 AM
bczee's Avatar
I would say that anything that help smooths out the air flow might be of some gain somewhere in the RPM range.. but how much is the question. It could help low speed throttle reponse..
It looks like the IAC port is covered (?, but can't see if clear from the pictures and write up that I have seen). That could aid in some flow being smoother over a stock one.
You might gain the same results (or better) with a good PnP Throttle body.. that is the route I would suggest for a bit more $ or time.
Old Mar 4, 2008 | 01:08 PM
TheSilverOne's Avatar
waste of money
Old Mar 4, 2008 | 01:31 PM
turbopaez's Avatar
I would have to agree waste on money
Old Mar 4, 2008 | 06:43 PM
RE AND CHERYL's Avatar
Ignoring their claims, all I can think of is if I install this it will further reduce the inlet diameter of the T/B and restrict airflow. I don't see how that gets me more power.
Re'
Old Mar 4, 2008 | 10:09 PM
TLewis4095's Avatar
It does not hurt the performance, but is not worth much more than a little low-end response improvment. Sell you one for $20 if you want to try it. Ported TB would be much better. IMHO
Old Mar 5, 2008 | 03:09 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
^^^^ agreed.
Old Mar 5, 2008 | 03:44 AM
gold98Z28's Avatar
Originally Posted by TLewis4095
It does not hurt the performance, but is not worth much more than a little low-end response improvment. Ported TB would be much better. IMHO
++2..
Old Mar 5, 2008 | 04:32 AM
bigfatls6's Avatar
Definelty a waste It looks like it would actually cost you some air flow because of the loss of volume in your throttle body. I looked at it in Jegs also. Thats the whole point of porting your throttle body to open it up and flow more air. I am sure what ever it gains you buy smothing out the air flow it will cost you because of the loss of volume.
Old Mar 5, 2008 | 06:51 AM
01z28auto's Avatar
I'll vouch for the waste of money. I had one in mine and did a before/after test @ the track. Absolutely no difference in mph. I'd spend the money somewhere else,if I had it to do over again.
