SeS Codes
Old Mar 5, 2008 | 03:53 PM
DarkJuggalo's Avatar
Default SeS Codes
threw a SeS today so i ran up to my school and plugged in a code reader and these r what popped up.
p0704 Clutch switch input circuit malfunction
p0420 Catalyst efficiency below threshhold.
the catalyst i know is a failing cat, im not worried about that one. but whats up with the clutch code? what does this mean? is this the reason im having clutch issues?
Old Mar 5, 2008 | 04:41 PM
Viper's Avatar
https://ls1tech.com/forums/general-maintenance-repairs/846690-p0704-clutch-switch-input-circuit-malfunction.html
http://www.obdii.com/ubb/Forum1/HTML/002126.html
http://www.gearchatter.com/viewtopic8984.php
sounds like the switch!
Old Mar 5, 2008 | 11:56 PM
all it effects is the cruise control? and where is the switch located.
Old Mar 5, 2008 | 11:58 PM
to adjust it on the cruise control side that is
Old Mar 6, 2008 | 09:17 PM
Tim@Rapid's Avatar
LS1Tech Sponsor
p0704 is a type c code. It will not turn on the MIL (ses) light. So who knows how long it's been stored in the PCM. It is located on the upper portion of the clutch pedal bracket. The switch is depressed when the pedal is up. The actual name of the switch is "Clutch Anticipate Switch". It has nothing to do with the cluth itself. It's only an input signal to the PCM. Hope this helps.
Old Mar 6, 2008 | 10:05 PM
ah i c, the SeS went away today. i just wanted to make sure it was nothing serious. i looked it up at school yesterday on alldata, and it told me to make sure wire is secure, or clean the switch for a fix. so i did so and no Ses, but the other code is gone too. thz for advice =)
