SLP cold air induction?
Old Mar 11, 2008 | 11:36 AM
BlackWS666's Avatar
Default SLP cold air induction?
I have been searching for hours trying to find anyone who has installed, or tested the SLP Cold Air Induction Kit. Advertised in summit(part #SLE-21033). SLP claims 10 RWHP........but haven't seen anyone with one installed yet. It is supposed to force air from the bottom up into the air box. I also know you can do a mod with a WS6 hood to route extra air threw the "nostrils", which also creates a true ram air effect at higher speeds. If anyone has some knowledge on these parts, or modifications then please share.
Old Mar 11, 2008 | 11:46 AM
pj4553's Avatar
I posted a thread about it a few days ago. Some people said it wasn't worth it and others said it was good for .2 on the 1/4. I'm going to pick one up probably. It's not like it's real expensive.
Old Mar 11, 2008 | 07:14 PM
BlackWS666's Avatar
True. Let me know how that works out for you brother. Thanks
Old Mar 12, 2008 | 12:29 PM
thebart455's Avatar
i asked that question a while back and every one told me that the slp cold air really wasent worth it to just get the lid. so i got the lid and my car runs good. so i used some of the money left over to buy other goodies
Old Mar 12, 2008 | 01:00 PM
Hardtop's Avatar
I would get the Fast Toys ram air over the SLP. It works.
Old Mar 12, 2008 | 01:31 PM
bigti99a's Avatar
its ok. what you will find people saying is a lid is a lid. i have the slp CA and havent had any problems with it but i dont know what additional gains are there because of it. i think it could be a little lower and forward for function. but i dd my car and if its raining i didnt want **** all up in it.
Old Mar 12, 2008 | 01:35 PM
2002Z28Camaro's Avatar
i made mine and i noticed i picked a few mpg ill find the link on how to make one give me a few min.
Old Mar 12, 2008 | 01:43 PM
http://www.evlls1.com/installs/install-coldair.pdf
ok copy and paste. mine problely isnt as good as SLP but for only $40 if that i thought id try it
Old Mar 12, 2008 | 02:19 PM
PewterScreaminMach's Avatar
The issue is you won't typically see dyno gains from the CAI because there is no great benefit to having it when the car is sitting still. But when you are blasting down the track at 100+ mph (or less...) and now the colder air from outside the engine compartment is being forced into it, the engine responds well.
If two people have the same cars and dyno the same with the same setups, only one has the cold air, I would expect it to have the advantage from a roll or at the top end of the track.
Think about it this way: it's $120 and it's absolutely not going to hurt you, but it very well could give you more power up top. Why not?
Old Mar 12, 2008 | 02:23 PM
5301113's Avatar
good info
Old Mar 12, 2008 | 02:30 PM
radz282003's Avatar
I'd go with a lid and FRA stuff. Save that money for something else, or see if you could find a used one. Mine did more to heat the coolant than give me more power at the track.
Old Mar 12, 2008 | 02:33 PM
I don't know if I'd take performance advice from the "slowest stalled car in northern CA". J/K
Old Mar 12, 2008 | 04:02 PM
ping2day's Avatar
I'm selling a new Fast Toys Ram Air. If your interested. I just didn't use it in my build. I race 1/8 mile mostly and i am also trying to lighten up my car.
Old Mar 12, 2008 | 04:09 PM
DarkJuggalo's Avatar
what do you mean u can reroute air to make it true ram air nostrel?
Old Mar 12, 2008 | 05:21 PM
Fast Toys Performance Parts's Avatar
Go with the FTRA. Is is a proven part that works very well. You can read about it at www.installuniversity.com
We also sell a kit to upgrade the SLP cold air kit to be similiar to our FTRA kit. That's a great option for people that already bought the SLP kit.
Old Mar 12, 2008 | 05:52 PM
camcamaro1991's Avatar
it increases "map load%", at WOT my map load was at 97% with out the slp cold pac, now its at 101-102%
i logged it with my HP Tuners
at 97% you are not getting enough air
at 100% you are at atom... pressure thats (good)
at 101-102% you are actually forcing air into the motor (best)
so the .2 gain is reasonable, and a small increase in hp is also possible, every car is different.
guys if i am wrong please correct me and i will fix it.
Thanks in advance.
