MTI Throttle Body Help?
Old Mar 14, 2008 | 11:31 PM
JWG01LS1's Avatar
Question MTI Throttle Body Help?
Need some help,
I purchased a MTI throttle body for my 01 Z, the guy who had it before me said MTI Bored out the little hole in the middle plate. He said it was for LS1s with bigger cams. He also said it would work with my car (stock cam) ! I went to my friends house and installed it, but after the install my car was ideling crazy, when i would come out of a gear and into nuetral the rpms would hover around 2500. I was wondering if this sounded normal, or when i put a bigger cam in it will it idel back to normal????? any input is accepted. thanx
Old Mar 15, 2008 | 12:23 AM
CRAGER's Avatar
Administrator
Depends on the cars (A4 vs M6), the cam size, and the idle in the PCM. You can always get a new blade. How big is the hole drilled out to?
Peace,
Craig.
Old Mar 15, 2008 | 12:24 AM
shoemike's Avatar
wow
how big is the hole?
Old Mar 15, 2008 | 09:05 AM
JWG01LS1's Avatar
Well the hole is pretty big compared to the stock one... its about the diameter of a pencil or pen. My car is a M6 by the way, and the cam i would like to go with is the MTI X1. Thanks for the help
Old Mar 15, 2008 | 09:28 AM
00T\A's Avatar
Thats a pretty big hole.
I would get a new blade.
Old Mar 15, 2008 | 09:40 AM
CRAGER's Avatar
Administrator
That is a huge hole, and don't try to epoxy it or rivet gun it...just get a new blade.
Peace,
Craig.
Old Mar 15, 2008 | 02:23 PM
JWG01LS1's Avatar
A new blade sounds like the way to go. but if i get the cam i want (230/228, 598/598, 112) would the throttle body work ok as is???
Old Mar 15, 2008 | 03:44 PM
Mong00z's Avatar
A second opinion is always best, but you may need to call MTI to find out.
Old Jan 31, 2013 | 12:35 AM
blak_ls1's Avatar
where can i get a throttle body blade for this throttle body? can i use the one from my stock throttle body?
Old Jan 31, 2013 | 12:58 AM
Machine-Master's Avatar
before you get crazy on the blade it might be the iac that is causing the issue what is the voltage at idle, do you know if it is a voltage issue, also did you unplug the iac at iddle and try the process all over.
