View Poll Results: Should I attempt installing this myself?
Do it yourself!
10
23.81%
Do it yourself with friends!
32
76.19%
DOnt attempt
0
0%
Voters: 42. You may not vote on this poll
Should I atempt?
Old Mar 18, 2008 | 03:17 AM
Silver UltraZ's Avatar
Default Should I atempt?
Ok fellas...
I recently purchased...
Pacesetter Headers (NO Cats)
Pacesetter ORY
PP Typoon Intake Manifold 85mm
PP Throttle Body 85mm
XR-1 Bullet Muffler. ( I have LM2)
Should I install all of this myself? Im pretty handy dont get me wrong. We have installed tons of car audio and recently have put headers on 3 GTOs. Im by no means a "gearhead" but would love to try unless its a bad idea.
Im also going to be removing the AIR and EGR systems.
Any tips? Or suggestions?
Old Mar 18, 2008 | 05:46 AM
RA4926's Avatar
do it your self, no need to pay a shop hundreds for something you can do and have fun doing. friends and booze are a necessary combination for a good install.
get the car safely as high as you can for the headers, helps alot. there are a few writeups on here that will go step by step with you on everything you plan to install.
Old Mar 18, 2008 | 05:52 AM
aNuBiS's Avatar
Intake and throttle body, I would say is a peice of cake, I have however heard of some nightmare stories on getting the gaskets lined up on the PP versions, not sure if they changed or modified that at all since.
Exhaust is a bitch to do without a hoist but not entirely impossible.
Old Mar 18, 2008 | 06:42 AM
Hilton's Avatar
Tough Mudder
I voted to do it yourself with friends, but if no one shows up, you really only need help for a few minutes. I asked my wife to catch the headers when I handed them up to her from the bottom.
Old Mar 18, 2008 | 08:28 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Having friends help, never hurts, IF you had no choice I would still suggest doing it yourself but hey, get the help when you can.
As for the intake, on a Fbody, use 1-1/2" tubing for the rear intake bolts, they hit the cowl and have a friend help with the removal, you WILL NOT break the oil psi sensor if you take your time. If you do it alone, there stand a good chance of ******* it up.
Old Mar 18, 2008 | 08:59 AM
2000SS1979's Avatar
I installed all of that stuff on my own. It was pretty easy and straight forward. I am 1 hour away from you. If you want some help let me know. I am more than willing to come out and help you out on the install.
Old Mar 18, 2008 | 09:28 AM
motoo344's Avatar
Ive done all of it, except I did an ls6 intake. Helps if you have friends.
Old Mar 18, 2008 | 09:40 AM
Camaro396's Avatar
I dont see any reason why you couldnt do it yourself. Save money and gain the experience yourself.
Old Mar 18, 2008 | 01:36 PM
Pntbll309's Avatar
I hear the typhoons are not good at all... But anyways I would do it all yourself, why waste mod money?
Old Mar 18, 2008 | 01:41 PM
zracer323's Avatar
Do it yourself! No need to waste money when a little time and effort can get it done!
DarkJuggalo's Avatar
try it yourself first, then go somewhere if u cant do it
Old Mar 18, 2008 | 01:43 PM
WS6_00's Avatar
its not hard to do, just time consuming.
Old Mar 19, 2008 | 08:08 AM
PewterScreaminMach's Avatar
Definitely give it a shot yourself with some friends.
Old Mar 19, 2008 | 10:23 AM
Hobb3s's Avatar
Get a couple of friends to help you out and it shouldn't be a problem. There's even a guy in here that's done it before and is willing to help you out, take advantage of his experience.
Old Mar 19, 2008 | 12:31 PM
joblo1978's Avatar
Do it yourself, I did, it's an experience.
Header studs would make the job alot easer. Don't forget to do plugs and wires as well.
Old Mar 19, 2008 | 03:15 PM
joker machine's Avatar
do it yourself, also save you $$$$$.
Old Mar 19, 2008 | 07:28 PM
LS1-NAVY's Avatar
do it yourself you can learn alot
Old Mar 19, 2008 | 08:05 PM
ealucero1's Avatar
Do it yourself, save some cash, and throw some new valve cover gaskets and a thermostat, and spark plugs in while your at it. Its a good time to tackle these areas when everythings off and out of the way.
Old Mar 19, 2008 | 09:44 PM
01ssreda4's Avatar
question......do you have a welder? but other then that go for it.
Old Mar 20, 2008 | 05:38 AM
waldershrek's Avatar
Say No To Welding!
And yes you can do all that stuff without a helper if you need to but obviously it's easier with a friend lending a hand.
