Carb setup for LS1
Old Mar 18, 2008 | 02:39 PM
05 GSXR 1XXX's Avatar
Default Carb setup for LS1
A buddy of mine just picked up a 76 280Z and has a ls1/t56 laying in his garage, he wanted to put a carb intake on the ls1 but the only thing we found was a intake on jegs that was like 900...
is there several vendors that carry this intake, its just going to be mild cam/heads... so he doesnt need a ***** out inatake..
links, price, drawbacks, install tips lol would be helpfull...and yea hes set on Carb since it has a painless wiring harness throuhg the car and doesnt feel like doing it over again( has a 305/th350 right now.)
thanks
Old Mar 18, 2008 | 04:17 PM
did a quick search on here and saw the base and victor jr kit.
the base says 1500-6500 rpm range
victor jr says 3500-7000 rpm range,
so obvously he would need the base, but he also has a cam in the ls1 thats mild-to upper mild lol in which on the instrustions says to not run any other cam besides there cam and long tubes...
is there any other brand that sells carb intake for the ls1 or edlebrook it?
Old Mar 19, 2008 | 12:58 PM
Carshopinc.com's Avatar
LS1TECH Sponsor
We carry the edelbrock kit:
http://edelbrock.carshopinc.com/prod..._id/76819/2908
We use this on our chevelle conversion and it worked pretty nice.... You ca purchase a gm intake also and use the programable msd controller to run it.
Carshopinc.com
Old Mar 21, 2008 | 02:48 PM
is there no other kits out?
Old Mar 24, 2008 | 10:55 AM
LS1TECH Sponsor
Right now msd is the only one making a controller that I know of.... You can use any of the carb intakes but will need the controller or a front mount distributor conversion.
Old Mar 24, 2008 | 12:11 PM
Lason's Avatar
My suggestion is to get the intake and seperatley purchase the MSD box. The edelbrock/msd ignition box included with the intake only uses "chips" to select timing curves and they are all too high IMO. The MSD version of the box uses the same chips and also allows you to plug in a laptop and set it to whatever you like along with setting timing retards for nitrous and low speed rev limiters for trans brakes.
I just fired up my Datsun project with the victor jr and MSD box and it all works like a champ. Ditched the holley for a edelbrock yesterday and runs much better.
Old Mar 24, 2008 | 01:19 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I'll post a few pics for ya later
Old Mar 24, 2008 | 01:28 PM
SUPERWAKE502's Avatar
Gm performance parts has an intake. Probably the one jegs sells. Scoggin dickey has it for 360 and I just got mine last week. As far as the msd box. The msd6010 has alot more capability than the elderbrock box that is also made by msd.
Old Mar 24, 2008 | 08:15 PM
Z28/2002's Avatar
I couldn't be happier with mine. The Edelbrock version box also has a laptop hook up on it.
Attached Thumbnails Carb setup for LS1-picture-003edit.jpg   Carb setup for LS1-picture-004edit.jpg   Carb setup for LS1-picture-005edit.jpg   Carb setup for LS1-picture-007edit.jpg   Carb setup for LS1-picture-001edit.jpg
Old Mar 24, 2008 | 08:59 PM
Lason's Avatar
Im digging that carb'd F-body! You dont see that everyday. Here are pics of my junk. Like I said, just got it running but the powerglide is still on the workbench waiting on a planetary and other than that just needs a driveshaft to be running. Will probably get started on the turbo setup this next winter, in the maen time Ill just tune the chassis in and get used to it.
and my ignition box mounted next to my fuse box in the glove compartment
and a couple pics of the car its all in
Old Mar 25, 2008 | 06:23 AM
ls1leadfoot's Avatar
damn that engine is sexxxxy!!!!!
wish i new how to work on a carb
Old Mar 25, 2008 | 11:05 AM
LS1TECH Sponsor
Here is the other Box as mentioned above...
http://msdignition.carshopinc.com/pr..._id/72792/6010
Old Jun 1, 2008 | 05:33 PM
ZMONSTER!'s Avatar
So from a daily driver stand point, in so much as driveability/reliability/gas mileage and power, which would be better the stock intake or a carb'd setup? Also is there anyone that makes a kit with all needed parts?
Old Aug 3, 2009 | 01:30 PM
Ls1Mx-5's Avatar
Would the 6010 work with the edelbrock intake?
Old Aug 3, 2009 | 03:57 PM
Z28/2002's Avatar
Yes it does
Old Aug 3, 2009 | 04:54 PM
Ls1Mx-5's Avatar
Someone said something about a 98 ls1 harness being different then any other year. Will the 6010 work on a 98 engine? Sorry bout jacking the thread, but this info should be helpful to other people as well.
