**NEW** BBK LT's, and ORY **LOT's of PICS INSIDE**
Old May 31, 2011 | 02:41 AM
  #161
Cstone812's Avatar
Originally Posted by 98z8uup
This is a shoot of my chrome headers after they have been in my car for almost 2 years.
Attachment 298587
They went from chrome to rainbow.
Old May 31, 2011 | 03:20 AM
  #162
98z8uup's Avatar
Yes they did. I drove my car every day for a year.
Old May 31, 2011 | 02:28 PM
  #163
98 Trans-am's Avatar
Originally Posted by J-Train
There are 02 bungs in the collectors of the headers. Also there is a second set in the y-pipe for a wideband or whatnot. You will need to cap them if you are not using them. I found two short oil drain plugs from Advance. 18MM is what you need.
Thanks man. That's what I needed to know! about to pull the trigger on them in the next couple of days
Old May 31, 2011 | 03:36 PM
  #164
98_TA_EMLC's Avatar
Originally Posted by 99'CajunFirehawk157
So other that the tunnel brace on a vert issue which is trash from the get go and the Y pipe issue for a vert, thats it as far as negatives for a vert?? After market tunnel brace and perhaps an E cut out will solve those issues...
yup...don't know what the ecutout is going to help with...could put one in the i-pipe and then move the i-pipe you cut forward to the right length...otherwise i'm not sure what you're talking about.
Old May 31, 2011 | 09:14 PM
  #165
J-Train's Avatar
Hmmmm yea i may try and get that when I install mine let me know how it goes.
Well, the clamp seems to have worked. I had to use quite a bit of copper RTV to get it to not leak at all. The LM1 I pipe has those slots in it to expand over the Y pipe outlet. Since you will be butting it up against the BBK y pipe and using a band clamp you have a bit of a issue getting it to seal up good with those slots in there. I got the damn clamp as tight as humanly possible and it seems good and secure and not leaking. I actually should have done the RTV on the whole damn exhaust at every junction along time ago.
That being said, I am only gonna leave that exhaust on there temporarily. It is not as raspy as other O/R y header combos & LM1, mainly due to the quality merge and collectors (IMHO). But still way to loud coming off the throttle and between shifts (A4).
Mind you I love a loud car, but just not exactly the sound I am looking for with the BBK's and LM1.
I really want to try a Spintech Pro Street dumped off the Y. I know that will still be loud but have a nice deeper tone to it.
Old May 31, 2011 | 09:27 PM
  #166
Cstone812's Avatar
Sounds like the install went ok I guess im going to have to pick up a clamp when i order the headers. How much louder is it with the headers? Ive read everywhere how loud headers + ory and lm1 is and thats what im looking for is loud If it sounds like complete **** though I may end up picking up a new catback to. Would you say someone that has never done a header install before can install the headers and y? Im still debating on doing this myself or having someone else do it....
Old May 31, 2011 | 10:10 PM
  #167
J-Train's Avatar
Follow the how-to's and you will do fine. Make sure you got a decent set of 1/4 drive sockets, extensions and ratchet. 10MM will become your best friend. I used a combination of shallow well and deep well 10mm and a nice 1/4 ratchet to get all the header bolts. I had to slip a deep well socket with a long 3/8" extension over the handle of the 1/4" ratchet to break the torque on the header bolts. And the closest to the firewall passenger side bolt can be removed easiest from the bottom. (although I went from the top installing all the bolts). Another tip is to make sure you have all the bolts on each header started before you tighten any of them. A good 3-4 turns can be got by fingers . Then work your way back and forth tightening them a little bit at a time. If you have any questions just PM me if you have specifics. Remeber every car is different and issues I had you might not.
I will try and get a video up tomorow if I can. It's pretty damn loud. You may or may not like it, everyones tast is different. It does not sound like the same car though.
Old May 31, 2011 | 11:13 PM
  #168
Cstone812's Avatar
Sounds good man yea I'm probably gonna do it myself ill let you know how it goes and yea post up a vid if you can!!!!
Old Jun 29, 2011 | 06:44 PM
  #169
Grr's Avatar
Grr
heres a couple quick pics of mine, easiest install ever!
Old Jun 29, 2011 | 07:43 PM
  #170
99'CajunFirehawk157's Avatar
Thumbs up
Cool, still happy with the chrome decision, they turn blue yet?
Old Jun 30, 2011 | 07:47 PM
  #171
Grr's Avatar
Grr
Havent had it running for more than 1 min, I love blued chrome headers though they have alot of character. gonna drive it this weekend
Old Jul 10, 2011 | 06:14 PM
  #172
Cstone812's Avatar
Just ordered my bbk lts and y what header bolts and gaskets did you guys go with?
Old Jul 10, 2011 | 06:26 PM
  #173
Nick_Rapitis's Avatar
factory gaskets...bolts too if i remember correctly...should be able to get some new ones at a dealership for relatively cheap
Old Jul 11, 2011 | 06:43 AM
  #174
toadzq8's Avatar
Well designed merge, better than most production pices.
Old Jul 19, 2011 | 03:00 PM
  #175
Cstone812's Avatar
Im installing these Friday on my z28 with help from another person does anyone have any suggestions before I start this? I got it on a lift today and sprayed some pb blaster on every bolt I thought I might be taking off and it looks to me like once I get the stock mans out the headers will just slide up? Any advice? Thanks.
Old Jul 19, 2011 | 03:16 PM
  #176
Thumbs up
Please POST pics of the install and your opinions...
Old Jul 19, 2011 | 03:18 PM
  #177
Cstone812's Avatar
Ill have some up saturday on here.
Old Jul 22, 2011 | 05:19 PM
  #178
Cstone812's Avatar
put the chrome bbks and y on my z28 today.....The headers slid right up with no problems at all the only hard part was taking all the old **** off....I would recommend these headers to anyone ill put up some install pics later
Old Jul 22, 2011 | 05:37 PM
  #179
Thumbs up
$349 ?
Cool, please post the pics...did you do motor mounts too?
Old Jul 22, 2011 | 05:53 PM
  #180
Cstone812's Avatar
$349 ?
yea man 349 off the ws6 store but I bought the msd wires and ngk plugs kit and you need 3 02 extensions because the bbk headers and y used all 4 02s if you want and 1 02 will bolt into the y without an extension no I didnt do motor mounts but I am going to have to get them because I do have some slight tapping on the drivers side....give me a lil bit and ill post up some pics
