Throttle Sticking!
Old Mar 22, 2008 | 07:13 PM
GothMetalForever's Avatar
Angry Throttle Sticking!
I've got a 2000 Camaro SS with a Wilson F.A.S.T. intake and throttle body. My problem is that lately the idle or throttle or something has started sticking around 1400-1600 RPM when I sit still and I'm completely at a loss for why it is doing this. There was even a point where I pulled into my aunt's driveway, and just before I shut it off, I was at 2000 RPMs, sitting still!!! Any ideas?
I've tried cleaning the throttle body out with Carb Cleaner, seems fine -- gas pedal seems fine -- the little junction box where the gas pedal is connected to seems fine. If I tap the pedal or rev it just a little bit, it usually comes free, leading me to believe its gunked up? But today I drove for a little bit and the problem didn't occur at all?
I'm totally lost and appreciative of absolutely any help. Any suggestions? Thanks guys.
Old Mar 22, 2008 | 07:15 PM
ssfast99's Avatar
get rid of the fast tb and get a nick williams tb
Old Mar 22, 2008 | 10:45 PM
myws6istheshiznit's Avatar
the old fast throttle bodies used to stick but most people upgrade the spring and that solved the problem. still a nice part.
Old Mar 23, 2008 | 12:10 AM
CAMAROZ28AQUINO's Avatar
Youre FAST tb explains that. Ive read many stories about that with that brand tb. However i have NOT heard any problems with the Nick Williams 90mm.
Old Mar 23, 2008 | 12:23 AM
Wow, I had no clue at all. Thanks tons guys! I really do appreciate it! I smoked some rice tonight just for you all! ;-)
Old Mar 23, 2008 | 01:22 AM
ZV8's Avatar
ZV8
can you adjust the idle with a screw driver on them by the TPS? I had this problem on my old trucks TPI engine, dont know if an LS1 can do this or not?
Old Mar 23, 2008 | 01:24 AM
RrCoX22's Avatar
setting the idle rpm has nothing to do with a blade catching/sticking
Old Mar 23, 2008 | 01:57 AM
ZV8's Avatar
ZV8
oh I C, its just geting stuck open, try some WD40? lol
Old Mar 23, 2008 | 08:19 AM
LS1SpeedAddict's Avatar
Add a spring like this guy did
We did the same thing on my dads formula and it fixed the problem
Old Mar 27, 2008 | 05:14 PM
Thumbs up
LS1SpeedAddict: thanks, that's definitely a much easier looking fix than pulling the TB apart and piggybacking a spring in there (if even possible)
