LT Headers or LS6 intake for first major mod?
If it is a manual, first consider that a cam is really not that much more than either of those and depending on the brand of headers, a cam could be cheaper and a LOT better.
If it is a M6 and a cam is out, go headers first. Look at my setup. I did the intake LAST with the heads.
If you get the intake go ahead and change the plugs and get an FTRA setup. Port the TB and do the coolant bypass while you are at it also.
go with the headers, I dont belive the intake will be worth as much on an otherwise stock motor.
If you have a 6 speed I would go for the LT's First.On my A4 LS6 intake made me lose a few horses Until I had the car Tuned.Now I have a cam so it really doesnt matter
But as Far as HP went on my A4 car the hedders have been the best mod so far(Night and Day).Thats just my .02 The Best V8 Stories One Small Block at Time
I'm happy with my Hooker LTs (install was EASY) and they fit like they came from the factory, but I don't know how they would do with cats (if they y-pipe will work with them...might have to shorten the collector to install cats......
Both SLP and FLP (both $$$) will work with cats (fit) but as you said, SLP's hang low so they might cause you problems....
Whatever you go with, make sure its JetHot coated....my hookers were coated by some other company (whoever Hooker uses) and after only 6 months the coating on the primaries is starting to burn through in places (fortunately its not up top where it can be seen)....
