Stuck Plug wires
Old Mar 27, 2008 | 12:24 PM
Y2K SS's Avatar
Default Stuck Plug wires
Sup guys. Got a problem and wondering if its only with these wire or not and what other wires should I consider. Anyway, I have had some MSD 8.5s on my car for a couple years and yesterday went to change the plugs and the damn wires wouldn't come off. Twisted and turned and almost broke my wrist when one finally gave. I also managed to break one wire inside the cap so I gotta get new plugs wires anway.
thanks
Old Mar 27, 2008 | 12:28 PM
ss.slp.ls1's Avatar
MSD 8.5's are pretty much one of the best wires out there. Some run Taylor wires but I don't see them being "better".
Old Mar 27, 2008 | 12:40 PM
BLACK2001SS's Avatar
put some ele greese on them to prevent that next time I have MSD on now but stock is fine they are so short its not a big deal.
Old Mar 27, 2008 | 12:55 PM
Y2K SS's Avatar
Some what???
Old Mar 27, 2008 | 01:04 PM
RoDan's Avatar
I think he means dielectric grease. The voltage is so high the dielectric strength of the grease is far bypassed and there is no problem with conductivity or anything. It prevents corrosion as well as the clips sticking on the plugs.
Old Mar 27, 2008 | 01:12 PM
needadvice's Avatar
None of the aftermarket wires will improve performance or power AT ALL unless you're running big horsepower engines, like over 600 RWHP. I've been through them all and the factory wires can't be beat. I have a tad less than 500 RWHP with my 427ci. Or just use the $36 wires from Advance Auto.
Old Mar 27, 2008 | 01:32 PM
Reject's Avatar
get some taylor's. i like those bad boys cuss of theyr boot design, has a thumb grip deisgn to them that makes pulling them puppies out look like childs play. you also hear the two clicks, sounds almost like you breaking your arm, real nice crisp snap sound to them.
Old Mar 27, 2008 | 01:37 PM
ealucero1's Avatar
But aftermarket wires tend to last longer and can handle multiple plug changes without damage. Aftermarket plugs can also stand up to heat better. I've never had a melted MSD, like I did with stock wires. Wether its a battery cable, speaker wires or plug wires, there will always be superior wires. This my friend is undebatable fact.
Old Mar 27, 2008 | 01:57 PM
BigD 275's Avatar
Have MSD wires on mine for over 4 years now (only about 3K miles on them - camaro has turned into a garage queen) and no problems.
Old Mar 27, 2008 | 02:17 PM
LS1crazy01's Avatar
I think wires on these cars are a pain in the *** with out any dielectic grease on them. Its always good to have a couple extra wires around incase you break them if you need to remove them. I did use dielectic grease on my taylors with the header install and 15k miles later I needed to pull one and it was still pretty hard to get off but at least it didnt break. I have read more about the MSDs being harder to pull off then Taylors but the MSD's are a little bigger so thats nice. The reason why I went with Taylors is becase its what Speed Inc. had in stock at the time. I do like the fact that there not that large because they dont come "that" close to the headers so I dont burn them up.
Old Mar 27, 2008 | 03:49 PM
Y2K SS's Avatar
So what do you do, just grease up the boot with that stuff?? Where do you get it at??
Old Mar 27, 2008 | 03:54 PM
LS1crazy01's Avatar
It usually comes with the wires when you buy them. Or you can get it at any parts store. You just squirt a little bit into the boot and then snap it on the plug. Hope that helps.
Old Mar 27, 2008 | 06:42 PM
Or put it on the plug first haha.
Old Mar 27, 2008 | 06:46 PM
DarkJuggalo's Avatar
im gonna go with msd 8.5s
Old Mar 27, 2008 | 07:12 PM
ss.slp.ls1's Avatar
Can't go wrong with those.
Old Mar 27, 2008 | 07:44 PM
Pntbll309's Avatar
I got MSds on mine and love them, if you want some stockers Ill sell you mine. Pm me if so.
Old Mar 27, 2008 | 07:56 PM
01ssreda4's Avatar
vise grips????
EDIT: a big ******* hammer!!!!
Old Mar 27, 2008 | 09:29 PM
ealucero1's Avatar
I used to have a plug wire puller that summit racing and most autoparts stores sell. It can help when pulling the wires. They're less than $10. Dielectric grease is a must when doing plugs you can literally fill the boot with it and put them on it helps to get the wire off, moisture out, and prevents arching. I buy the big tube so I always have it on hand. Remember to fill the plug side and the coil pack side.
Old Mar 27, 2008 | 11:48 PM
Y2K SS's Avatar
Thanks, thats what I need to know.
Old Mar 27, 2008 | 11:50 PM
COD02SS's Avatar
I'm running Summit race wires and i like them a lot. We're 60 bucks
