flowtech longtubes,pacesetter ory,borla=
Old Mar 31, 2008 | 09:13 PM
myfirstgm's Avatar
Default flowtech longtubes,pacesetter ory,borla=
lots of rattling from the ory against the floor board,what can i do?thinking of selling the ory and catback for true duals,but will i have the same problem because of the headers?
Old Mar 31, 2008 | 09:15 PM
lastcall190's Avatar
If the y-pipe is rattling, I would bet money that duals will too. How old are motor mounts? Another solution is either the mufflex bumpstop hanger, or the BFH mod on the floorboard.
-J
Old Mar 31, 2008 | 09:18 PM
myfirstgm's Avatar
-J
car has 70k im guessing original motor mounts.what is the bfh mod?
Old Mar 31, 2008 | 09:23 PM
ScrapinBye's Avatar
BFH=big ******* hammer, which means beating the **** out of your floorboards and anything else in the way so your pipes won't touch them and rattle. If I were you, dont do this caveman ****. Spend the extra time and do the prothane mounts. I did it with the LT's already installed. It's definately worth it once everything is said and done.
Old Mar 31, 2008 | 09:29 PM
myfirstgm's Avatar
LOL big ****** hammer,i should of known
Old Mar 31, 2008 | 09:54 PM
DarkJuggalo's Avatar
one of the sponsors sells braces for the y pipe as well
Old Mar 31, 2008 | 10:02 PM
It might be primitive, but sometimes it's the last resort to get better clearance after tucking the pipes up as high as they could go. Caveman ****
-J
Old Mar 31, 2008 | 10:20 PM
nncfan8's Avatar
Lightbulb
sounds like you need some new muffler bearings!!
http://kalecoauto.com/index.php?main...products_id=10
Old Apr 1, 2008 | 05:24 PM
ScrapinBye's Avatar
-J
You're right, sometimes you gotta do what you gotta do to make it work. Prothane mounts are a good choice though. I was real skeptical before I did them because I read how much of a pain in the *** they are to install with LT's in the way. It was a hard job, but no more banging ORY! Like I stated earlier, you will thank yourself when it's all said and done.
Old Apr 1, 2008 | 05:35 PM
I did prothane mounts too... well, after getting one in I said **** it and brought it to my friend's shop to do the other I'd have rather swapped the cam again than do motor mounts. Any day.
-J
Old Apr 1, 2008 | 07:53 PM
02silvaZ's Avatar
pace y sux!
Old Apr 1, 2008 | 08:26 PM
sscamaro22's Avatar
If I were to put the motor mounts on while my car is on the lift and all whole exhaust off would it still be a PITA
Old Apr 1, 2008 | 10:41 PM
ramairracer's Avatar
i had the same prob. with my flowtechs and their y pipe lots of banging at takeoff and slowing down, my solution true duals! i tried the heater hose mod, and a rubber hanger like themufflex but it still rattled, do it i love them
