Mechanical oil pressure gauge
Old Apr 1, 2008 | 08:55 PM
blkbird's Avatar
Default Mechanical oil pressure gauge
Well, i finally hooked one up to see what was really going on in my car..... Dont think its good. On a cold start the mechanical one read 30ps1 and the dash read about 39ps1. This is with swapping out the oil pump to a melling pump. Ive never seen any shavings in the oil and when i replaced the oil pan gasket in january, i didnt see any accumulation of anything in the remains below. The car really doesnt make any kind of noises. It squeaks a little when cold but goes away after it warms up. What could be the deal???
Old Apr 1, 2008 | 11:17 PM
FMX05's Avatar
30psi is fine? At a cold idle you only NEED ~20-25psi(real psi not the dash gauge). What is the hot idle and WOT@6k rpm?
Old Apr 1, 2008 | 11:18 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
How did you hook up the mechanical gauge??
Old Apr 2, 2008 | 11:45 AM
blkbird's Avatar
I tapped the fitting above the oil fillter. I havent let it get to full temperature yet cuz it started leaking a little from the fitting i installed. When I rev it the rpms do go up to +/- 50psi. Cant see what rpm im at cuz i mounted the gauge in the engine compartment.
Old Apr 3, 2008 | 02:08 PM
Z28/2002's Avatar
Thanks
Old Apr 3, 2008 | 04:55 PM
blkbird's Avatar
Once I fix the little leak im gonna take it out for a spirited run to see what the pressure is like at hot idle.... That may not be for a while. I just bought a new truck so dont really need to drive it around much anymore....
Old Apr 5, 2008 | 06:38 PM
blkbird's Avatar
Ok. So i let the car warm up and on hot idle on the mechanical gauge it reads around 16-17psi which is close to what the interior gauge is reading. I rev it to about 5K rpms and it goes to about 50psi on both. Now, should I be worried??
Old Apr 6, 2008 | 10:13 AM
99FormulaM6's Avatar
10psi/1000 rpm is minimum you sure the oil pump is installed right? nothing messed up with the pick up tube?
Old Apr 6, 2008 | 10:25 AM
blkbird's Avatar
Nope. Everything was installed right. I did the pickup tube with the oil pan off. My car idles at about 750rpms.
Old May 28, 2008 | 11:11 PM
Duffster's Avatar
I taped that same spot for a few months and unfortunately, I had a full mechanical gauge in a pillar pod. It leaked. . . both ends. Good luck.
Old May 29, 2008 | 06:13 AM
Z28/2002's Avatar
Did you tap into somewhere else?
Old May 29, 2008 | 12:07 PM
mycamaroSS's Avatar
what should be the right psi for idle/mid rpm range and high rpm range. Sorry for hijacking, just want to know
Old May 29, 2008 | 03:40 PM
mycamaroSS's Avatar
Bumperusky
