F.a.s.t. Vs Wieand Intake Maniforld
What is your opinion between the two intakes for the price? Im going for "bang for the buck". Thanks
FAST Intake vs. WIEAND / LINGENFELTER ALUMINUM INTAKE MANIFOLD
Matt
Matt
If you want the value, the LS6 as stated above is it hands down. For the most power the FAST , and for the best looking but the least heat-soak power robbing inconsistant runs application, the Alum ones. We have seen as much as 20 rwhp loss between a cool first run on the dyno w/the alum ones & a hot engine compartment heat-soaked one.
Pretty looking bling, but power? no.
how cany anyone compare the street warrior intake its not even out knowone really knows whats it capable of. i think something is up because its release date keep getting pushed back. kinda like the new greg weld wheels
BBK is right in the middle with power and price. If you run 10 laps back to back with no cool down you will have a heat soak issue. But other than that run a cartridge roll up the runners to knock off the casting flash and throw a good TB on there.
