Does this car have headers on it?
Old Aug 4, 2003 | 12:13 PM
Scoobie's Avatar
Default Does this car have headers on it?
Ive called the dealership, no one there knows what the Hell i am talking about. I cant tell from the engine bay shot, but does this picture look stock? Its got a lid, a shifter, a Maf and a few other things, so i thought it might have them.
Old Aug 4, 2003 | 12:24 PM
4thGENRETARD's Avatar
Default Re: Does this car have headers on it?
Headers are bolted on both side of your engine. they look like 4 separate metal tubes conecting into one (Colector). It is what gathers the exhaust out of your engines heads (Where the spark plugs go). The stock exhaust manifolds are rusty cast iron.
U are obviously a newbie and are going to catch a lot of flak for posting this question. Don't let it get u down, this is a great learning site.
Old Aug 4, 2003 | 12:28 PM
2001CamaroGuy's Avatar
since it still has stock tips, I'm going to say no because most people don't spend $600+ on headers/header y-pipe and run it through the stock cat back....
post the engine bay pic....that should tell us for sure....
Old Aug 4, 2003 | 12:50 PM
Scoobie's Avatar
Im not that new thanks though for the info. Actually the dealer just called me back. Shes sending shots, find out in a sec. Also, this picture was posted because how low the y pipe is hanging. I know the stocker sits low on the LS1 cars but this one looked lower to me, less flat?
Old Aug 4, 2003 | 12:53 PM
Scoobie's Avatar
Also, the car is a 1LE car, i already figured out it once had SFC welded on, i can tell by the burns in the carpet. Who ever installed them let them get too hot and burned right through the carpet. The dealer already said there are weld marks below, but couldnt tell me about the headers. Perhaps the stock cat back was put back on as the stock shifter was. The shift boot is broken, and it has a manual fan switch but no routing ?? id say mr previous owner took some stuff off before trading in.
Old Aug 4, 2003 | 12:56 PM
Scoobie's Avatar
Here are the old shots i had to go off of, maybe you can tell if it had them here or not, still waiting on the new ones.
Old Aug 4, 2003 | 01:04 PM
Scoobie's Avatar
Well its not the shot i was hoping for but here it is. Please let me know. THanks
Old Aug 4, 2003 | 01:05 PM
Ramair346's Avatar
I'd have to say that screams stock manifolds
Old Aug 4, 2003 | 01:06 PM
Scoobie's Avatar
Ok Thanks, when the dealer told me there were 4 black tubes coming out the head, i had to investigate.
Old Aug 4, 2003 | 02:01 PM
Yeap stock manifolds.
Old Aug 4, 2003 | 02:08 PM
pimpmaro's Avatar
Yup, stock manifolds, but hey... at least you've got SFCs!
Old Aug 4, 2003 | 05:51 PM
99 Black Bird T/A's Avatar
and a lid!
Old Aug 4, 2003 | 06:07 PM
Dave Carney's Avatar
SLP Y-pipe.
Old Aug 4, 2003 | 07:06 PM
CAT3's Avatar
Restricted User
Used to have a bolt in rollbar by looking at the carpets burn mark placement, but then could be the SFC's! Hmmm, probably driven, and maintained very well, by a great old lady for groceries, and had the rollbar for safety reasons, kinda like the performace version of side impact beams right?
Old Aug 4, 2003 | 07:59 PM
badpewter-z's Avatar
LS1TECH Sponsor
definetly stock, look at the first picture you can see the crushed factory y-pipe
but i'd buy a set for it
Old Aug 4, 2003 | 08:13 PM
SNAXS's Avatar
Looks to me like it might have been a performance car. Like posted above it has a rollbar. I dont think any 12 sec. car would put a roll bar in their car. Maybe it was sprayed?
Old Aug 4, 2003 | 09:22 PM
Narcosynthesis's Avatar
Where are the heat shields on those stock manifolds? Whats up with that ebrake handle too? You sure you wanna buy that car?
Old Aug 4, 2003 | 11:00 PM
Colonel's Avatar
"since it still has stock tips, I'm going to say no because most people don't spend $600+ on headers/header y-pipe and run it through the stock cat back...."
My '02 has the stock muffler and tips. It is internally stock and ran 11.82 NA. There is such a thing as an electric cuttout ya know? Some of us like to be sneaky.
Old Aug 4, 2003 | 11:09 PM
Stu's Avatar
Stu
Is that a low pressure compression fitting in the brake lines?
Old Aug 5, 2003 | 01:36 AM
CAT3's Avatar
Restricted User
Actually that fitting is more likely a high pressure compression fitting, looks like mine. I had my stock line cut at a hydraulic shop, and the extensions are made from a SS braided line. Another way to set up a line lock.
