full bolt ons and cam only enter here.
Old May 15, 2008 | 10:32 PM
Wicked_muscle's Avatar
Default full bolt ons and cam only enter here.
Ok I am at a point where I'm about to order a cam. My car right now has just about every bolt on. It has k&n filter -> SLP lid ->80mm tb -> ls6 intake coming out of pacesetter long tubes -> catted td with spiral flows coming out the back.
I've been looking at cams for about a month or so and I want a cam that will get me in the low 12's and optimistically in really high 11's maybe, and putting out about 400hp. I will not be getting heads anytime soon so I need a cam that will be safe with stock heads. I'm currently looking at a 232/234 .640/.590 112 LSA cam?
Old May 15, 2008 | 11:42 PM
MGMC's Avatar
TR230, proven cam thats good with stock heads/intake and a nice free flowing exhaust
Old May 16, 2008 | 12:16 AM
camcamaro1991's Avatar
x2 i have the TR230/224 111 and love it.
i dont have the new dynos #'s with it yet sorry.
Old May 16, 2008 | 01:14 AM
do you guys know anything about this cam TR "Split Pattern" - 230/236 .592/.602 112 LSA ? And what does the split pattern mean?
Old May 16, 2008 | 01:21 AM
232/234 duration with .595/.598 lift and 112 LSA seems to have a good lift that would work well with stock heads. Any idea on the numbers this cam would provid power/track. Btw the cam has to provide good mid and high range power.
Old May 16, 2008 | 01:55 AM
Nimitz87's Avatar
my buddy loves his 230/230 .603/.611 110+4 cam
get a custom grind from pat G.
Chad
Old May 16, 2008 | 02:25 AM
Chad
what kind of numbers does he put down track and dyno?
Old May 16, 2008 | 02:31 AM
Nimitz87's Avatar
385 on an MD dyno I believe...don't quote me though. I'll find out for certain what it is.
track, don't know.
Chad
Old May 16, 2008 | 03:15 AM
94'BLKBRD's Avatar
What about the TSP Torquer 3?
Old May 16, 2008 | 03:20 AM
2000Hawk's Avatar
Well if you want a good track cam, don't look at horsepower numbers as a benchmark. Are you M6 or A4? That comes into play also on how your car will perform at the track.
-Joel
Old May 16, 2008 | 06:45 AM
BlkBird2000's Avatar
Spend 25 bucks and have Patrick G figure you up a custom cam. Makes the cam for YOUR car.
Old May 16, 2008 | 09:27 AM
99blancoSS's Avatar
Start looking at the big picture. Is this a street car at all? What trans do you have?
You can run 12's on the stock cam if you have the right suspension. Also dont get caught up in the big cam syndrome. Lot of guys on here think they should brag because they run a big cam. My car was faster on the street with a TR224 than a custom ground 234/240
Big cams are drag racing and suck on the streets for power through the low and mid range rpms and dont let anyone tell you different. You can mill the heads all you want you but cant make up for small cubes and a big cam vs a proper cam for the weight and gearing.
We've got a guy in our section who ran 12.1 all day long with the proper stall and a tr224. He added some juice now and is well into the 11.'s and had to buy a roll bar.
Old May 16, 2008 | 09:33 AM
03Sssnake's Avatar
Good advice!! I have outrun a few of my buds from a dig that went with a donkey dick cam.
Old May 16, 2008 | 09:38 AM
Hilton's Avatar
Tough Mudder
I have the Torquer 3 mentioned above. With a tune it drives great.
Old May 16, 2008 | 09:48 AM
tylerdj's Avatar
I would say a TSP torquer...v2 or v3. I've seen this put down some really good power/ET's.
Old May 16, 2008 | 10:17 AM
-Joel
well I have an m6.
Old May 16, 2008 | 10:18 AM
who's patrick g? hope I'm not insulting anyone.
Old May 16, 2008 | 10:20 AM
the v2 is a 233/239 right or what are the specs on those cam including lift?
Old May 16, 2008 | 10:27 AM
Mr. Brett's Avatar
I'm in pretty much the same situation and am about to install a TSP 228R. After doing a ton of research, it seemed like the best off the shelf cam for a street driven car to run low 12's cam-only. I only go to the track 2-3 times a year and I could care less about dyno numbers. I just want a fun street car with plenty of torque across the board. Once you start looking at 230+ cams, you start sacrificing low end power and driveability. 99blancoss is right on. Don't just go for a big cam, go for something that meets your needs and works with your setup.
Old May 16, 2008 | 10:35 AM
99blancoSS's Avatar
In fact I offer custom ground Comp cams, Comp magnum 7.4 pushrods an PAC 1218 racing springs (good to .600 lift) for $600 delivered.
