long tube bolt on?
Old May 17, 2008 | 08:16 PM
ItalianZ28Stallion's Avatar
Default long tube bolt on?
how long will it take to bolt on a set of long tubes my self i have all the tools to do it. i just have never try on a ls1 camaro im use to old schools. can anyone help me out maybe someone has some pics or there oppion
Old May 17, 2008 | 09:39 PM
s346k's Avatar
took me exactly 4 hours to remove the complete stock exhaust and air/egr from a 2000 a4 camaro and install pacesetter long tubes. i had a couple buddies helping, but there was definately more bsing going on than work.
my only advice: change plugs when doing the headers, find some corvette o2 wires, or buy the extensions, AND GET THE BUMPER OF THE CAR ABOVE YOUR KNEE ON JACKSTANDS. i've done a lot of pacesetter installs and every one of them required the headers to go in almost vertically, get the car as high as you safely can.
Old May 18, 2008 | 02:43 PM
Nsty98LS1's Avatar
if you have access to a lift and all the right tools you can do it in about 3 hours, also if your doing motor mounts at the same time give yourself another hour or so.
Old May 18, 2008 | 03:42 PM
95 Z28's Avatar
If it's your first time, I'd give it a good long day, maybe a little more honestly. Save yourself a headache later and do poly motor mounts while you have the manifolds off.
Old May 18, 2008 | 04:57 PM
snake charmer's Avatar
Header install is a piece of cake . Just wear gloves , take your time , and dont break any bolts . Shoulf not take much time at all . Might want to do poly mounts while you are at it as some header installs you may have to lift the engine up a bit and to do this you will have to remove the bolts that are in the oem mounts .
Good luck !
Old May 18, 2008 | 05:08 PM
ttranssam's Avatar
same here it was so much easyer than i thought. i did it all by myself in four hrs. the only help was putting them into place, and i just cut the tab...took 5 min. also i took the coils all the way off, more room.
Super Speed's Avatar
The best tip I can give you is to get a ratcheting wrench
Old May 18, 2008 | 05:13 PM
im2fast4u98z28's Avatar
i'de use an air ratchet after you get the bolts started. saves alot of time.
