TB Bypass mod writeup with PICS!
Old May 20, 2008 | 05:55 PM
neeshSS's Avatar
Default TB Bypass mod writeup with PICS!
So as I'm waiting on my FAST 92/92 I decided to go ahead and get the TB bypass mod out of the way. I took a few pictures of the quick install. What I used for this mod: 1. 2 ft of 5/16" inside diameter rubber hose
2. 2 Hose clamps with a 5/8"-1/4" clamping range
3. Pliers
4. Screwdriver or socket set.
First here is a dirty picture of the car, and don't mind how filthy my engine bay is, I know I need to clean it.
Here is a pic of the bay..
Here is the hose on the right side of the throttle body..
Here is the left side of the throttle body..
And here..
OK! here is the hose I used
And the Clamps, check out the toe
I cut the hose a tad long, Always cut it a little long! Especially if you don't have an extra length lying around.
Here is a picture of the left side with the new hose installed
And the right side.
And the finished product!
Hope this helps a little bit for anyone new.
Old May 20, 2008 | 06:12 PM
LETHLS1's Avatar
clean. good walkthrough.
Old May 26, 2008 | 04:26 PM
Ripper415's Avatar
nice pics/writeup. you dont need to get any kind of high temp rated hose? i thought regular fuel line hose would melt? at least that's what i heard when i was doing my catch can a while back.
Old May 26, 2008 | 07:58 PM
SSNISTR's Avatar
I used the two rubber hoses that were on the car and just added a metal tube to connect them.
Old May 26, 2008 | 08:55 PM
jetlag's Avatar
No it's just coolant..that hose is fine..same as I used.
A lot of people still do it that way, but in my opinion this is the best way... less places to leak and a lot cleaner looking.
Old May 26, 2008 | 10:37 PM
94TRANS's Avatar
any block off things needed to put over the original spot?
Old May 26, 2008 | 10:40 PM
jetlag's Avatar
No. Some people cut the tubes off the throttle body..or leave them alone.
Old May 26, 2008 | 10:57 PM
Black99CamaroSS's Avatar
it doesnt hurt to put vacuum caps over the TB tubes incase you want to reverse the mod so dirt doesn't get inside.
Old May 27, 2008 | 07:17 AM
hagerbump's Avatar
This is one of the cleanest ways I have seen to bypass the throttle body. Simple mod with a clean simple set of instructions. Thanks for the effort.
Old May 27, 2008 | 11:09 AM
Spd-Kilz's Avatar
Looks like I just figured out what I'm doing on my day off work.
Thanks for the write up!
Old May 27, 2008 | 11:36 AM
wtfx100's Avatar
Uh so where does the other end of the hose go to?
Old May 27, 2008 | 11:40 AM
SSNISTR's Avatar
I bought little black rubber caps at Radio Shack for like 2 bucks. They keep the dirt from getting into the TB and look fine....
Old May 27, 2008 | 01:27 PM
jsteele90's Avatar
one to the radiator and the other to the metal tube on the passenger side where you removed the original line. easiest install ever.
Old May 27, 2008 | 02:38 PM
neeshSS's Avatar
I would have put some caps on, but I'm pulling it of "any" day now for the 92.
Old May 27, 2008 | 02:44 PM
slt200mph's Avatar
Thank you for the pics but this is what you would call old news. People have been doing that for about 10 years now.
www.installuniversity.com
www.ls1howto.com
Old May 27, 2008 | 02:55 PM
mycamaroSS's Avatar
i only see one pic
Old May 27, 2008 | 09:05 PM
ProjecT 9's Avatar
Old Nov 16, 2008 | 07:00 PM
skeeters65's Avatar
Just found this thread..
I understand how to do it now I would like to know why? What does this do and why is it better than stock??
Thanks
Old Nov 16, 2008 | 07:08 PM
jetlag's Avatar
Thanks
Less hot coolant flowing around the throttle body = cooler air = mo' powah!
But I didn't notice a difference.
Old Nov 16, 2008 | 08:54 PM
jrob56's Avatar
www.ls1howto.com
im sure he knows that, but this is a good write up with quality pictures. ill be doing this soon even though im sure there is almost no difference at all lol
