average "full bolt-on" gains from tune
Old May 26, 2008 | 08:54 PM
LS1ne's Avatar
Cool average "full bolt-on" gains from tune
hey guys how much do you think a tune would get me with bolt-ons:
  • FTRA
  • K&N FLILER
  • SLP LID/SLP 85mm MAF
  • HELIX TB SPACER
  • FULLY MODDED TB BY SMOKIN87TA
  • LS6 INTAKE
  • MSD WIRES/DELCO IRIDIUMS
  • SLP UNDERDRIVE PULLEY
  • JET HOT COATED (IN & OUT) PACESETTER HEADERS/ORY(NOT COATED)
  • SLP LM1 CATBACK
  • REBUILT TRANS. W/TRANS GO SHIFT KIT
by the way its on a 99 ls1, if im not mistaken the stock cams were bigger on these cars. the tuning will be on EFI LIVE w/a wideband O2. im just wondering what i'll gain and cant wait!
Old May 26, 2008 | 08:57 PM
jetlag's Avatar
It just depends on how the stock tune is now... some cars are better than others..they are all different.. You might gain 3hp, or you might have 20.
It isn't a set thing..but be sure to post in the Dyno section when you get numbers.. If I was you I'd swap back to the stock MAF if you still have it.
Old May 26, 2008 | 08:58 PM
LS1ne's Avatar
I just bought one lk an hr ago..i read the sticky on bolt ons and finally decided to get one ...do you think it'll help?
Old May 26, 2008 | 09:05 PM
jetlag's Avatar
The stock MAF flows plenty of air...usually you only upgrade it when making some real power..like forced induction 450+hp
Also, sometimes aftermarket MAFs are harder to tune.
And the throttle body spacer won't do anything... all your other mods are good though.
But, my car has pretty much the same mods(stock maf, no spacer)...and it put down 330/340 untuned.
Old May 26, 2008 | 10:27 PM
cookba's Avatar
i have a 2002 Z28 A4
mods:
SLP lid and free air mod
ported TB
MSD wires and NGK TR55 plugs
Kooks 1 3/4 headers w/ catted Y
GMMG catback
Transgo shift kit
after tune made 341rwhp and 348rwtq.
all cars are different and will respond to the same mods differently. there was just a car posted by one of the sponsors that got around 370rwhp with just bolt-ons.
Old May 26, 2008 | 10:34 PM
LS1ne's Avatar
wow, those are some nice #'s! im hoping to get around 350ish
Old May 27, 2008 | 12:54 AM
Pntbll309's Avatar
I dont have an ls6 manifold yet, but I pulled 42rwhp and 29tq out of a tune. Im shooting for 350 with the manifold and true duals.
Old May 27, 2008 | 08:14 AM
mycamaroSS's Avatar
i have a freak cause i dynoed my car stock and it IS stock and i got 330rwhp and 350tq. Cant wait to install my full boltons when i get home and see my numbers
Old May 27, 2008 | 08:36 AM
ZHAWK154's Avatar
i have all the usual bolt ons and hypertech powerprogrammer tune - put down 359rwhp and 367rwtq! i was suprised to say the least
Old May 27, 2008 | 04:03 PM
King Nothing's Avatar
since you have lt's, 350 MIGHT be possible for that 99 . . . but then again go to the "right" dyno and you'll hit that do you know what kind of dyno the place has?
Old May 27, 2008 | 05:29 PM
Mike@ZMS's Avatar
350 WILL be possible with LT's. Hell, I made 345rwhp/360rwtq with a tune and my only mods were Lid/Filter, 85mm Maf, Ported TB, NGK TR-6 plugs, MSD wires, and a magnaflow muffler.
I now have QTP LT's and was able to easily pull my friend that was always able to pull me. He put down 355rwhp/365rwtq (not exact, but real close) with the same mods, minus the ported TB and he has Pacesetter LT's and the K&N FIPK.
With the mods on my car now, I SHOULD be able to see 370-375 after I go back for another tune.
Old May 27, 2008 | 06:39 PM
davered00ss's Avatar
Moderator
You are going to gain a lot from the tune. with all your mods, you are not getting the Hp you should out of them without the car being tunned for them.
Old May 27, 2008 | 08:19 PM
LS1ne's Avatar
its a mustang dyno im assuming...he tunes with efi live.
Old May 28, 2008 | 12:15 PM
radz282003's Avatar
Most bolt-ons; 366/372 with a tune (Dyno Dynamics.) Lid, full exhaust, thru 17X10.5" wheels and 315/35/17s.
Old May 28, 2008 | 04:48 PM
my buddies 98 withe lt's td's and a tune made in the 330's, but his is A4 . . . you M6 guys will always dyno higher than us A4 guys. tr6 plugs huh? you runnin nitrous?
yep i've seen some people dyno numbers higher than other with the same mods . . . just a different dyno and usually don't those mustang dynos read higher?
Old May 28, 2008 | 05:05 PM
Mike@ZMS's Avatar
I have everything for the N2O, including a N2O only tune (Dry hit... 100hp). I just need to run the main feed line and do some more wiring. On a mostly empty bottle (2 LBs of N2O) I put down 435rwhp.
I just need time and motivation to finish the install.
Old May 28, 2008 | 07:55 PM
LS1ne's Avatar
do m6's usually get more on a dyno than a4's?
Old May 28, 2008 | 08:17 PM
TA1364's Avatar
When I got mine tuned I picked up 3hp. Make 320 through a locked converter.
Old May 28, 2008 | 08:38 PM
LS1ne's Avatar
wow..i thought most would be around 345ish..what do you mean by "locked" converter
Old May 28, 2008 | 09:37 PM
jetlag's Avatar
Yes, always.
