cut outs after cats... is it worth it?
Old May 29, 2008 | 09:54 PM
hlaalu's Avatar
Default cut outs after cats... is it worth it?
i dont have any room to put cut outs before my cats because my cats are connected right to my long tubes. ive always thought cut outs were cool, but would it even be benificial as far as power and noise to put them on behind the cats?
Old May 29, 2008 | 10:03 PM
Slvr00Bird's Avatar
It would definitely be louder if you opened it up after the cats, opposed to letting it run through a muffler... It won't be as loud as if you had before them, or if you didn't have them, but you should still be able to tell very easy.
I'd say just cut the cats out and have at it.. but I see you're from Cali..
Old May 29, 2008 | 10:34 PM
hlaalu's Avatar
^damn cali emission laws!!!
Old May 29, 2008 | 10:36 PM
RrCoX22's Avatar
obviously you will pick up some rwhp and of course it will be louder... just matters if its worth it on the pocket
...in the end if you gonna do that might as well do it the right way
Old May 30, 2008 | 12:02 AM
snake charmer's Avatar
+1 you will see some power with the cutouts . though you might want to look into another exhaust sytem or setup yours different for what you are wanting to do .
Old May 30, 2008 | 10:18 PM
TopFlite's Avatar
I have Pacesetter LT's and an ORY on my Z with a cutout and did notice a little more mid range and top end kick with the cutout open. However, I did it mainly for sound and wasnt expecting much as far as hp gains go. The placement of my cutout is directly under the rear passenger seat.
Old May 31, 2008 | 12:37 PM
hlaalu's Avatar
you just have one cutout?
Old May 31, 2008 | 12:48 PM
TopFlite's Avatar
Yes, just 1.
Old May 31, 2008 | 12:53 PM
Camaro396's Avatar
I also have mine, under the backseat.
Old May 31, 2008 | 12:57 PM
hlaalu's Avatar
so did you guys put the cut out at the y pipe merge?
Old May 31, 2008 | 01:01 PM
Camaro396's Avatar
I cut a section out of my exhaust I pipe, right about under the backseat, and band clamped it in there.
Old May 31, 2008 | 01:16 PM
hlaalu's Avatar
oh i see now. do you notice a difference even though you have a catback already?
Old May 31, 2008 | 01:35 PM
Camaro396's Avatar
Yes, it runs way better with the cutout open. And sounds alot better.
