what spark plugs to use with 402cid with patroit stg 3 heads , and what MAF sensor ?
What Mass Air Flow do you use with the 402cid engine ?
What spark Plugs do i need ?
Do i have to Replace my Fuel Pump ? if so what to use ? is the wiring going to be ok ? cause i hear when using the Stock PCM i have a voltage drop ???
do i need to install a Fuel Regulator if i go with Fast 46Lb/hr Injectors ? or will everythign work out in tuning ?
