LS6 Intake prep...
Old Jun 8, 2008 | 01:06 AM
71-Camaro-98's Avatar
Default LS6 Intake prep...
This is pretty much the only thing I need to do to be able to throw my LS6 intake on my LS1 correct?
Old Jun 8, 2008 | 01:48 AM
motoo344's Avatar
Thats all I did. Are you removing your air/egr system?
Old Jun 8, 2008 | 01:28 PM
Yeah, I will be.. I just need to get some block off plates.
Old Jun 8, 2008 | 01:53 PM
rel3rd's Avatar
When I swapped mine, I also had to take a hammer & tap the stock coolant lines down slightly...which wasn't a big deal.
In other words, I made sure that the intake was able to sit down on the heads nice and flush, before bolting it down. That way there was no un-needed pressure (from the underside of intake manifold) from using the intake bolts to draw it down and force the coolant lines down.
Old Jun 9, 2008 | 09:23 AM
BlackTA519's Avatar
Make sure to get some clothes-pins (I used 4). You will not be able to completly remove the last 2 bolts on both sides of the intake. The clothes-pins will come in handy for holding the intake bolts out of the way when removing and installing the intake.
Old Jun 9, 2008 | 10:14 AM
regency's Avatar
for the coolant lines to clear all you need to do is grind the ribs off the bottom of the intake
Old Jun 9, 2008 | 10:53 AM
rel3rd's Avatar
Not ALWAYS the case, as I found out on my car, which is why I explained to original poster what else to do, to ensure they clear.
FWIW, I used a small air powered angle grinder and ground all of the ribs off, just to make sure there was no issue with them (the ribs), beforehand.
Old Jun 9, 2008 | 01:43 PM
bigti99a's Avatar
if i where you i would buy an OPS unit ahead of time. i was very careful and still broke it. i have 100+k on the clock and it was brittle. you can always take it back if you dont need it. i also replaced the air and egr gaskets when i put the block offs on.
Old Jun 14, 2008 | 12:53 AM
Ok, I am drawing a blank on the OPS... But the intake I purchased comes with the rails, injectors, coolant lines, vacuum boost and fuel lines. Can I just use all of the rails and lines from the LS6 or would it just be easier to use my stuff (except injectors)?
Old Jun 14, 2008 | 12:58 AM
Ah!!! Oil pressure sensor... Got it. Is it really that easy to break when taking of the intake? Are you supposed to reach under and unhook the connection before pulling the intake or what?
Old Jun 14, 2008 | 07:51 AM
bigti99a's Avatar
if you are doint this alone chances are its going to break. if you have abuddy guide the vaccum line very gently around it you may be ok. its a tall black plastic thing with a connector on top. and when i did mine i just left the fuel lines connected to the stock fuel rails and dropped them back in. if you use different rails you need a tool to get the fuel lines off and back on.
Old Jun 14, 2008 | 11:53 AM
Where can I get one of those fuel line disconnect tools?
Old Jun 14, 2008 | 12:04 PM
motoo344's Avatar
You should be able to get one at an autozone or peb boys or whatever auto store is around you.
Old Jun 14, 2008 | 12:08 PM
EVIL z28's Avatar
You can get a fuel line dissconnect from just about any parts store. Im not positive but i think its 5/16 piece of plastic. If you unhook the vaccum line from the brake booster you can lift the line over the OPS.
Old Jun 14, 2008 | 12:23 PM
I was just on LS1Howto.com and it says that it is a 3/8" fuel line disconnect tool. It will be easier for me to just disconnect it then switch injectors and rails. Other than that I am most likely going to use the stock coolant lines but thats it, the LS6 intake will come with everything else.
Old Jun 15, 2008 | 02:50 PM
EVIL z28's Avatar
Yeah you're right it is the 3/8 fuel line. I just checked it last night. I put the injectors and fuel rails on my LS6 before i put it back in too. I think it was easier that way.
Old Jul 10, 2008 | 12:32 AM
Can someone show me a picture of the OPS and where exactly it is so I can know where to be careful when I swap my intake, thanks.
Old Jul 10, 2008 | 08:58 AM
bigti99a's Avatar
its on the driver side behind the intake, closer to the center than the head(hope that makes sense). it is a black plastic cylinder with a wireharness run to the top.
Old Jul 10, 2008 | 09:27 AM
HavATampa's Avatar
Here's a picture of the "OPS" that I stole from another thread. It's got the green connector on top. Tons of info and pictures on this procedure can be found by doing a quick a search. No need to unclip the connector. Just remove the big vacuum hose (red arrow from the other pic) from the brake booster and leave it attached to the intake manifold. Take your time and don't pull hard. I went an extra step and removed the plastic cowling pieces under the wiper arms. It doesn't have to be taken off, but gives you an extra few inches to see and put your hands.
Attached Thumbnails LS6 Intake prep...-oilpressuresendingunit-1.jpg   LS6 Intake prep...-brakebooster2.jpg
Old Jul 10, 2008 | 10:37 AM
ss.slp.ls1's Avatar
Yes, it is very easy to break the OPS. The brake booster line hooks right around it.
