LS1 Throttle cable bracket
Old Jun 13, 2008 | 09:24 AM
whitesmoke00's Avatar
Default LS1 Throttle cable bracket
I am currently building throttle cable brackets for the ls series motors. I have in my shop a 2000 camaro ls1 intake with EGR. I have finished a single and a double hole cable bracket. These fit and line just fine. I have had one of my guys try this on an ls6 intake and the throttle cable is not in line with the throttle body it is approx. 1/8" off. Does anybody have any info on these intakes being different?
Old Jun 13, 2008 | 09:51 AM
veee8's Avatar
GM must be making them again, I ordered one yesterday, and they said it was in TN. and be here next week. We will see.
We made one patterned off of an 02 SS with TC (LS6), and it works perfect with my old LS1 intake.
Old Jun 14, 2008 | 08:42 AM
Default ...
anyone else know anything
Old Jun 14, 2008 | 09:51 AM
JTom's Avatar
mine worked fine as well when i swapped from my ls1 to ls6 a few weeks ago.
Old Jun 14, 2008 | 12:25 PM
veee8's Avatar
What throttle body are they using?
Old Jun 14, 2008 | 12:52 PM
the one at the shop is a 2000 ls1 camaro and the one it was tried on was a 2002 ls1 that is goin in a c3 corvette.
Old Jun 14, 2008 | 07:23 PM
veee8's Avatar
Not sure what to tell you. We made an exact copy off a bracket off of a 02 f body, it worked perfect on my 00 f body intake. Maybe your 02 LS1 came out of a vette, they have drive by while TB's, and the bosses are a little different (not finished machined) compared to the LS6 intake on the 01-02 f-body. The new bracket I ordered, (which was discontinued for a long time, I assume that is why you made them), is off of an 02 TA with traction control. I know this will work, since thats what we used as a pattern to make my old one. They are like $5.
Old Jul 1, 2008 | 03:15 PM
veee8's Avatar
Just picked up the bracket, retail was like $12. Let me know if you need dimensions from it.
Old Jul 1, 2008 | 04:02 PM
Default yeah
that would be cool. let me know some dimensions
Old Jul 1, 2008 | 07:59 PM
veee8's Avatar
I will post them up tomorrow when I get to work.
Old Jul 2, 2008 | 10:33 AM
veee8's Avatar
Overall length is 2.740" , measurement from bracket mounting surface to center of first cable mount is 1.900", to center of second cable mount (cruise) is 2.140" with both mount bolt holes horizontal, the rear part where the cables mount, is at an aprx. 72* angle. The bottom of the slot for the throttle cable, appears to be about where the center of the rear bolt hole is. Hope this helps, let me know if you need something else.
Old Aug 18, 2011 | 11:55 AM
2000dreambird's Avatar
i know this thread is 3 yrs old but i need a Throttle cable bracket that will work on my LS3 swap
Old Apr 5, 2012 | 08:19 AM
kainedogg's Avatar
Are you using an LS3 intake? If so I have a friend with the solution.
Old Apr 5, 2012 | 10:26 AM
ZQ8LS1's Avatar
Anybody have the GM part # or make a bracket for the LS1 ???
