anyone elses Pacesetters do this after 3 weeks?
I have the same problem as the OP and considered JB Weld, but didnt think that it could withstand the hot *** temps. headers would put it thru. What brand was this "exhaust leak sealer?" I might try this instead of pulling my headers and sending them back to Pacesetter.
I asked in a couple of forums about running solid motor mounts, but 80% of the replies were not to do them unless you like jiggling in your seat and possible teeth chatter when running a large cam at every intersection you come to.
So yes they're stock.
Why whould they include them? That's right, they're an EXHAUST company.
Buy poly motor mounts. You may have to spend a little extra for them, which I am sure may kill some of you, but it will cure the banging. Solid is another option, which I went with.
Like mom always said, "Do it right the first time....."
BTW my headers leaked also when I put them on at the collector on the driver's side. I had them rewelded on the inside by a friend of mine and had him grind down the weld to smooth it out. Has done OK so far for 2 years.
