Victor Jr. timing controller?
Old Jun 19, 2008 | 10:11 PM
adrenalinedrumma's Avatar
Default Victor Jr. timing controller?
Hey i was just wondering if I have to use the timing controller that Edelbrock offers with the victor jr. or if I can use the MSD 6010 instead, or if i have to run them both. Thanks in advance.
Old Jun 23, 2008 | 08:47 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
If you still have the factory wiring harness in the car then you should be able to use the 6010. Call MSD to be sure though
Old Jun 23, 2008 | 08:02 PM
oh well im doing an ls1 swap into my '79 silverado so there are no wiring harnesses.
Old Jun 24, 2008 | 06:46 AM
Z28/2002's Avatar
I'm running the Edelbrock box on my car and haven't had any problems with it.
Old Jun 24, 2008 | 12:35 PM
Oh ok. Does the Edelbrock box come with software for tuning?
Old Jun 24, 2008 | 12:45 PM
jay_lt4's Avatar
edelbrock box doesnt use any software, plug and play with their 6 chips that all have 36* timing at wot(too much for most lsx engines)
Old Jun 24, 2008 | 09:21 PM
ok so either one would work though?
Old Aug 3, 2009 | 01:24 PM
Ls1Mx-5's Avatar
Does the 6010 have the same wiring harness as the Edelbrock unit?
Old Aug 3, 2009 | 02:13 PM
Ls1Mx-5's Avatar
How does the 6010 work with efi?
Old Aug 3, 2009 | 03:55 PM
Z28/2002's Avatar
The 6010 has an extra connector for the step retard and step control but other than that it is the same harness.
Yes it can be used with stock EFI setup but you need the adapter harness, part # 8886
Old Aug 3, 2009 | 05:14 PM
Ls1Mx-5's Avatar
Thanks, but would it work without the gm engine harness?
