Header install on Race Ramps?
i just jacked up the car and put 2 10' by 10' wood blocks under the front wheels and the ramps on the back. i was able to sit indian style under it! after the install i know i can drop the headers and re install em in under two hours now. air wrench is bad ***, good luck
bro i just did it on ramps. All you have to do is jack the rear up so the car is level on the ramps and jack stands. No need to have the front higher than the ramps, just level the rear out and you will have enough room.
No way it could have been done with less because the collector would hit the ground.
1 Post
no i used my floor jack, i dont think it was much more than 10 inches off the ground... to the bottom of the wheels. it was suspended on the a arms. and i got it in easier than the driver side.
If you are measuring 10" from the bottom of the tires with the car behind held up by the chassis, then that is plenty of room.... but the car on 10" ramps is different because the suspension is loaded then.
