98 LS1 - Installing LS6 Intake off a 2000...Can I?
I have a 98 T/A. I just got a new LS6 intake in the box. It says part no. 12560251, for 2001-2004 LS engines.
So, can I use this thing? What is dif. about a 98, 99 and 2000 vs 2001-2004? Am I screwed?
The way my luck goes, I better just get the right lines. Good to know that is the only thing I need to worry about. One guy was telling me my mechanical throttle body would not bolt up.
the throttle bodys are not a problem all the 98-02 tb's will bolt up to the LS1 and LS6 intakes... you many need to get some block off plates if you are taking the E.G.R. stuff off.
yea i remember seeing some on a website, i cant remember wich though i want to say thunderracing.com? im sure it wouldnt be hard to make your own though, but be sure to seal them with some rtv or something.
heres a link to it you can also buy them in a pair of 2.
http://www.ws6project.com/user_stor/...oducts_id=1764
You also want to check and see if the intake has the threaded inserts on it for the throttle linkage bracket. The two that I have done did not and I had to drill and press new inserts in.
