V8 Firebird vs. Trans AM
Old Jun 23, 2008 | 03:36 PM
formula23's Avatar
Default V8 Firebird vs. Trans AM
Basically I found a car that I strongly believe was origonally a firebird, and swapped in an ls1 and 6 speed. You can tell by the photos that it does not have the raised spoiler and it says firebird on the doors instead of Trans Am. Aside from cosmetic differences, what would be different about the two cars. And is it worth purchasing at this price. Please give feed back asap
Thanks - David
http://www.carsoup.com/used/detail.a...DealerGroupID=
Old Jun 23, 2008 | 03:47 PM
jetlag's Avatar
Well, it clearly says its a Formula...but I still think that's a little bit high.
Old Jun 23, 2008 | 04:05 PM
99NMB's Avatar
firebirds were made with the v8 they were called FORMULA's look identical to their v6 buddys.
Old Jun 23, 2008 | 04:09 PM
formula23's Avatar
Well if you are refering to the yellow print on the side of the car, I assure you that it says firebird, I have driven the car, and have other photos I could upload. Additionally it has a WS6 tag on the back, so if it is a formula, did they ever make a formula WS6? Just seems like BS to me.
Old Jun 23, 2008 | 04:11 PM
kerryt1's Avatar
Yes, there is such a thing as a Formula WS6.
Old Jun 23, 2008 | 04:38 PM
jetlag's Avatar
Well, either way it costs too much
Old Jun 23, 2008 | 07:45 PM
02silvaZ's Avatar
yeah they made formula WS6's 98-00 and believe it or not (wait this is gonna blow your mind) they even made formula firehawks, wow!
Old Jun 23, 2008 | 07:48 PM
89Formulaws6's Avatar
they made formula ws6's in the 80's haha too
Old Jun 23, 2008 | 08:25 PM
formula23's Avatar
Ok, I guess what my question really comes down to would be. Is there any difference between a firebird and trans am, aside from the obvious engine, tranny, and cosmetics. Is the suspension different, I don't know?!?! I assume there is no rev limiter or anything silly like that. Just curious if I would be screwed if it turned out to be a V6 made into a V8 instead of the straight up factory built Trans Am.
- Thank you for your replys
-David
Old Jun 23, 2008 | 08:35 PM
Soul TKR's Avatar
To be honest man... just get a TA. Unless you really want a formula. That way you won't be regretting it later...
Old Jun 24, 2008 | 11:36 AM
Bad Blu Formula's Avatar
formula23 for president!
Old Jun 24, 2008 | 02:49 PM
Titanws6's Avatar
Can you repost the link, I can't see the car!
Look at the inside of the driver's side door, there will be all sorts of codes on there to tell you what that car really was when it came off the line.
