SLP 1.85 Rockers...
Old Jun 24, 2008 | 09:34 PM
cowboyup's Avatar
Default SLP 1.85 Rockers...
ok.. The LS2 guys couldnt answer it.. How 'bout you guys?
Here is my setup:
Stock LS2 short block
Stage II LS6 heads
224\220 581\581 116 Stealth Cam
I have the stock 1.7 rockers on..
The question: Can I install the SLP 1.85 rockers?
((.581/1.7)*1.85 = .632 lift..
and install Patriot Dual springs that support .650 lift..
Doable?
OR will the valve hit the piston...and is the extra lift worth anything
Old Jun 25, 2008 | 12:03 AM
silverLSWON's Avatar
are your heads milled?
Old Jun 25, 2008 | 07:36 AM
teke184's Avatar
most aftermarket cams advise against higher ratio rockers due to fast ramp rates.
so my guess is NO...even if it did clear the pistons
Old Jun 25, 2008 | 01:42 PM
cowboyup's Avatar
no..the heads are not milled..
I guess 1.85's are a no-no..
Old Jun 25, 2008 | 07:44 PM
Randy WS6's Avatar
Maybe drop to a Comp 1.75 rocker
Old Jun 26, 2008 | 07:03 AM
Michael02hawk's Avatar
What he said - except no guessing about it, No.
Old Jun 26, 2008 | 07:27 AM
teke184's Avatar
"Maybe drop to a Comp 1.75 rocker"
or save the money from the rockers and spring upgrade and put it towards something that will actually make more power.
perhaps a FAST intake
Old Jun 26, 2008 | 02:12 PM
Randy WS6's Avatar
Well, I run the Comp Pro Mag 1.75" rocker with a Crane 250/266-.632/.632-112 witch raised the lift to .651/.651 and been running it for two years now with no problems what so ever and shift at 7300 rpms.
Old Jun 26, 2008 | 05:14 PM
cowboyup's Avatar
Yes, but you have pistons.. And I'm sure they are fly cut..
I'm just afraid the valve will hit the piston..
Old Jun 27, 2008 | 05:39 AM
teke184's Avatar
you're still talking .598" lift with the cam you listed if you went with the 1.75s
with the duration of that cam, you're likely fine
but its worth checking
