View Poll Results: Please read description in thread prior voting.
Filter
86.64%
Lid
87.10%
Fast toys ram air (Or similar)
86.18%
Ported MAF Ends
86.18%
Bellows
85.71%
Throttle body (ported, or after market)
86.18%
Intake (Stock upgrade, ported or aftermarket)
85.25%
Electric Water Pump
84.79%
Headers
86.64%
Exhaust
87.10%
Cut out
86.64%
Pulley
86.18%
Cam
24.88%
Lifters
27.19%
Push Rods
30.88%
Rockers
29.49%
Valve Springs
29.95%
Ported heads (profesionally done)
25.81%
Ported heads (home builder done)
25.81%
Block
10.14%
Crank
12.44%
Rods
12.44%
Pistons
12.90%
Turbo
68.20%
Nitrous
71.43%
Super Charger
69.12%
Multiple Choice Poll. Voters: 217. You may not vote on this poll
Stock internals.. What's it mean??
Old Apr 3, 2009 | 12:28 AM
  #41
nemss1's Avatar
would rear end gears be an internal part since its inside the case and touches oil?
...or considered a bolt-on?
Old Apr 3, 2009 | 05:48 AM
  #42
odarabla's Avatar
This thread is stupid!!
Old Apr 3, 2009 | 07:17 AM
  #43
Mumbles's Avatar
Awesome! I guess this is what the world is all about. Its just about the terminology and what comes to mind when using it. Some people will call an SUV a "car." I think thats stupid. A car is a car and an SUV is an SUV. To them, "car" simply means "automobile." In which case any automobile could be called a "car." So "stock internals" to some is simply crank/rods/pistons, but the actual definition IMO would include the valvetrain, oil pump, timing chain and ect. (I'm sure I'm forgeting somthing). Anyways, this thread is not stupid. It is what comes from different points of view and differences of opinion. Thats all. No need to judge.
Old Apr 3, 2009 | 07:26 AM
  #44
jam01's Avatar
Originally Posted by LIL SS
I see a lot of people posting up that a cam swap and head swap retains stock internals. Since I have been on this site (almost it's entire existance) the understanding of internals refered to pretty much anything that touched oil (excluding the TB and intake due to the PCV system). Even the way the external engine forum label is writen:
It doesn't say anything about cam or heads. I'm wondering when this shift of cam and head swaps became "stock internals"
I'm wondering what people feel are internals these days..
Crank, rods, pistons are roating assembly and are deffinately stock internals.. IMO a cam, heads are internals. Even 1.85 rockers IMO are borderline since they change valve train both in lift and duration.
no offense to this site.... but this has been settled befor this site was around oopps i mean since al gore invented the internet. bolt ons you's to be carb, ignition, intake, headers exhaust sys , air cleaner , valve covers. anything that really did not require dismantling the engine to the point it does not run. these are my definition and what was taught to me. but everybody has there own opinion. even what i mentioned really doesnt make sense to a point, but there an easy bolt on.
Old Apr 3, 2009 | 07:28 AM
  #45
jam01's Avatar
that was being stupid. and actually the rear uses lube not oil.
Old Apr 4, 2009 | 12:43 AM
  #46
riceburnerZ28's Avatar
stock internals to me is everything inside of the block that was originally installed from the factory. I.E. crank, pistons, rods..
Old Apr 5, 2009 | 02:02 AM
  #47
RiceEaterZ's Avatar
+1 anything you can't see without taking **** off, and needs to bathed in oil constantly
Old Apr 5, 2009 | 01:59 PM
  #48
zacht's Avatar
yeah i would have to say its not that hard to do. stock internals would have to be your block and rotating assembly. stock bolts/bearings too! i would say the valvetrain is a whole new system. as well as other bolt ons-ie FI system/ nitrous.
heads and cam can be swapped onto a stock bottom end and produce good results. now wild heads and cam, maybe a power adder will push the limits of the rotating assembly.
Old May 20, 2009 | 02:23 PM
  #49
NemeSS's Avatar
stock internals means block, crank, stock bearings, rods, pistons,rings and lifters.
