hmm... too much rasp/obnoxiousness
thanks in advance, all opinions appreciatedmichael
You could also add 2 or more bullet mufflers to the exhaust. Keep this in mind... I recently weighed a Dynomax Bullet muffler 18" long 4" dia it weighed 10 lbs 6 oz. A high flow magnaflow Spun Cat weighs 2 lbs 5 oz. imo.. I'd rather Add a couple cats and gain 5 lbs and loose 3-5 hp than add a 20+ lbs of mufflers in hopes of saving those couple hp. Less weight helps on all aspects of a cars dynamics while hp only helps in acceleration and imo the tiny hp you save going with running extra mufflers is completely negated by the added weight.
The sound of ORY/GMMG is beyond horrible because the rasp is so extreme. It takes a lot to get rid of it. But the end result can be awesome sound.
If you don't want cats, you can go with a Hooker or Magnaflow. It's much cheaper than adding all the pieces necessary to making your GMMG work. And you'll come out ahead selling your GMMG. But I tried a Hooker for a while. It was much quieter, but some rasp still got through.
Basicly you need some sound absorbing material like found in Magnaflow, Hooker, etc. Just some dents or ridges or baffles will not do it. You need to knock some of the bark off of it. An LS1 doesnt need any help making rasp so you have to choose your muffler(s) wisely when running an ory.
, i was looking at either a borla xr-1 but borla seems to be pretty high normally.. or a magnaflow bullet a buddy of mine has the same setup i'm looking at right now(with the bullet in the i pipe before the gmmg catback) and i'll be listening to it tonight. i try not to go by videos because most peoples videos cant capture most of the tones and to me most of the videos of idle's and people revving up different setups just sounds horrible because of that... or maybe its just my speakers
one of the main reasons i didnt want cats was A. cost and B. if you get a cheap one, its not going to flow worth a crap (from what i've read)
well i'll let you guys know what i end up doing..
and thanks alot again for the quick posts and all your info
michael
btw 98silverttz if i end up going the route of selling my gmmg i'll let you know
thanks,
michael
