Header installation questions?
Old Jul 20, 2008 | 08:56 PM
jrob56's Avatar
Default Header installation questions?
Im installing headers, ory, cutout, into the stock catback. Ive got my list of parts needed and just wanted to post it up and see if anything is missing.
QTP LT's
TSP ORY
Race Ready Cutout
NGK TR-55 Plugs
MSD Wires(is it worth it or just use stock?)
GM metal gaskets and bolts
Last two I have a quesion. What did you do for 02's? extension? corvette rear o2's?
Where is the best place for the EGR intake block off as I am removing AIR and EGR?
Thanks a lot,
Josh
Old Jul 20, 2008 | 11:35 PM
Omec's Avatar
just to give ya a heads up you may have a problem getting your stock cat back to line up prop. meaning the tips will be all out of place. you may get lucky tho. somthing to keep in mind.
Old Jul 20, 2008 | 11:41 PM
jrob56's Avatar
a couple buddies of mine have had it on two camaros, one currently, the rectangle tip stock catback, with zero issues. theyll be helping with the install well atleast one maybe both. why would it not line up?
Old Jul 20, 2008 | 11:49 PM
Omec's Avatar
mine didnt but this was w/ kooks stuff. my tips were off. no matter tho because i was getting it replaced anyways.
Old Jul 21, 2008 | 12:14 AM
jrob56's Avatar
o well the first car was with pacesetter ory and the second with tsp, and i have a tsp. it should work and if it doens well make it thanks for lookin out though ill let post up how it goes!
Old Jul 21, 2008 | 12:21 AM
frankmarroquin's Avatar
Everything you named should be about it...
Old Jul 21, 2008 | 08:17 AM
Raise's Avatar
Buy some antiseize for your spark plug threads
Old Jul 21, 2008 | 08:36 AM
FCar2000TA's Avatar
Veteran: Air Force
Stage-8 locking header bolts.
FYI, your best bet to install headers is to unbolt the motor, and jack the motor up about 4 inches. The headers should slide in pretty easily. From the bottom, obviously.
Old Jul 21, 2008 | 11:00 AM
lastcall190's Avatar
I made a thread on this type of question a while back, but can't find it in a search now for whatever reason... take the drain plug and oil filter out and they should slide right in with the car high enough, no need to jack the motor unless you can't get them in like that. Good luck.
-J
Old Jul 21, 2008 | 12:54 PM
s346k's Avatar
looks good, man. if the richardson boys are helping you (mainly nathan as michael is worth next to nothing when it comes to working on cars haha) it will go together fine and you will not have any problems. nate knows what he is doing, just call him if he isn't there and you have problems.
Old Jul 21, 2008 | 01:02 PM
Intercooler2's Avatar
Are the stock gaskets not reusable?
Old Jul 21, 2008 | 01:24 PM
SSmoken's Avatar
qtp's come with new ones. spliced the old ones onto some bosch ones and made them long enough.
