Sound Clips of my GMMG, Custom O/R Y and Flowmaster Merge
well it's a bit bigger than yours 246/252 .615/.625 110lsa
Now remember that this is also a 396ci motor with 12:1 compression
Now it has not been tuned for the LSX manifold and the change in exhaust
The difference in over lap is alot
Mine has 29*of overlap
Yours 10* of overlap
sounds good man...you going to the track soon...scc is on next friday...i dont think i am going to have my hood by then ...also the weather stripping looks nice too...
you know that ram air adds like 50% of the exhaust sound right
Now it has not been tuned for the LSD manifold and the change I exhaust
The difference inover lap is alot
did you see my driving vid bottom of first page?
On monday i had the car out, and day time temp was 92* my water temp gauge actaully rose above 210*
I was taking some pics of my car idling. prolly took 10 mins.... But then i started driving again to get the air moving back to the motor and it barely came down. So i guess with the FTRA the motor can over heat has your water temp gauge ever gone that hi before?
Car is completely sealed... When i put the lower air box into the radiator support i put weather stripping down where the air box would sit, then i reseal the lid again, this time a lot better, and what you saw in the vid. I sealed it right under the induction of the lower air box so hopefully like your dad was saying i hope it is all preasurized now....
Well Chris i really wanted to wait for cooler weather...
Do you have, or can you get some pics how you sealed your lower airbox/lid? I'm about to ditch my FIPK and go the lid/SSRA route, so I'm interested how to completely "seal" off the lid and lower box.
For the lid, all i did was take thin weather stripping and outlined my whole diameter of the lid. much like if you were to get a new K&N air filter, they supply you with a gasket for the lid..
And for the lower air box. i unbolted the 4 10mm bolts look to see where the top of the FTRA sits when the lower air box is sitting on it and i put the weahter stripping accordingly.......
No, i know you have a bigger cam, for some reason our cars seem to lope the same. Like you said i have 10* vs your 29*... the tuner said while tuning my b/c my cam is cut on a 110+4 the car acts like it has 20*+ of overlap
I'm at 491 now
nope my temps never rose past 210 even in summer the temps that always get high on me are the trans, so i am getting a 3qt + deep pan from B&M...
where are you reading the water temps from the stock guage...
#34
thats true your car is pretty choppy, does sound very similar. I do think different size cam sound different but once you get about 10-20 of overlap I think the tune has more to do with the rythem of the lope. my tuner is going to do a 1 bar SD tune to get rid of the MAF should hit over 500rwhp
I'm at 491 now
I'm at 491 now
#36
when mine is like 170 it says it is over 200 on the stock gauge haha
#39
Don't know if you have found out anymore about the overheating, but my car started doing that and it continuously got worse until it went far into the red once. I ended up cleaning out the whole system and putting in new coolant. It's been perfect ever since .
