De-wire mod
Old Jul 31, 2008 | 12:50 PM
fortmyerspolice's Avatar
Default De-wire mod
So my car started to smell kinda bad, and I found out my passenger carpet was wet, so yesterday I decided to rip apart the interior and clean the carpet up. Since I was there already, I also decided to do the de-wire mod. For those of you who have rewired stereo system like I, I thought it would be a good idea to get rid of all the excess wiring you don't need. I also ripped out some of the matting underneath the carpet. All in all, I saved at least 5lbs of just wiring. Saved a couple pounds ripping out some matting too.
For you weight junkies out there, this is a easy mod to do if you have an aftermarket stereo system. All in all I saved about 10lbs of wire and carpet matting. I haven't found the leak but I also found out my driver's side is doing it as well . I'm going to do the drivers side once I have some time. Also painted the seat mounts so they don't look rusty.
Old Jul 31, 2008 | 02:01 PM
TORCHD 02 TA's Avatar
you should not have removed the matt underneath the carpeting unless it was trashed. That is noise dampening material
Old Jul 31, 2008 | 02:27 PM
Difference not even worth mentioning. I'll leave the driver's side matted.
Old Jul 31, 2008 | 03:50 PM
camaroguy26's Avatar
I hope you found and fixed your leak! torchd is right though, I took mine out from the pass side cuz it was all molded from a water leak, and now my interior is a bit louder. still not bad but I need to get some new stuff for it
Old Jul 31, 2008 | 04:03 PM
while the carpet and padded is out, you can always put dunamat down.. yes it is a bit heavy, but there will be no noise at all
Old Aug 1, 2008 | 10:42 AM
99blancoSS's Avatar
The leak is from the gromet in the firewall where you pass the wires from the engine compartment to the interior of the car.
And sound deadening material doesnt eliminate noise completely, it helps to reduce it.
Old Aug 1, 2008 | 07:35 PM
chrs1313's Avatar
i did the same dewired mod when i hooked up my jl audio speakers and McIntosh amp...saved me like 10lbs in wire and stock amp in rear fender...also when i took the sound deading off my carpet is was around 16lbs total...so 26lbs is not bad ...
but it is louder in the car...that just means i have to turn the Mcintosh up some more
Old Aug 1, 2008 | 07:37 PM
Did you get rid of all the wire all the way back to the HU or did you cut it
Old Aug 2, 2008 | 12:34 AM
Empatho's Avatar
that's allot of wire, I'm going to add this to my to do list.
Old Aug 2, 2008 | 12:13 PM
chrs1313's Avatar
i got rid off all the amp wire/useless other wire and cut it by the head unit...and all the sound deading...
Old Aug 3, 2008 | 08:53 AM
theblur98ss's Avatar
One weekend I pulled the whole interior. I got rid of all the extra wires, relays, sound deadening, firewall plastic, door bars, air bags etc. All in all I ended up with a little over 100lbs. I was very disappointed all the more the wire weighed though. It did clean up my engine bay getting rid of all the unused connectors.
Old Aug 6, 2008 | 10:48 AM
transamsam98's Avatar
I am redoing my stereo comple custom wiring can anyone help me figure out what/ where to remove the stock stereo wiring. I have traced the harness to where it enters under the glove box but am afraid to cut until I figure out the path it takes from there. it is a 2000 trans am 6 speed if that helps. if there is a how to or a write up with pictures/ diagrams that be a ton of help.
Old Aug 6, 2008 | 11:35 AM
Soul TKR's Avatar
HOLY CRAP!!! Got any pics of that engine bay?
Old Aug 6, 2008 | 12:19 PM
x2
Old Aug 6, 2008 | 02:24 PM
dutinsss's Avatar
i'm going to do this one of these days. probably when i do that abs and tcs delete. i just hate taking my interior apart.
Old Aug 6, 2008 | 09:27 PM
x2
Here's a couple pics. It's really dirty and needs some neatening but you get the idea.
Attached Thumbnails De-wire mod-alive-004.jpg   De-wire mod-alive-001.jpg   De-wire mod-alive-003.jpg
