Why do my QTP headers hit the k-member??
Old Aug 4, 2008 | 05:06 PM
bowtieman81's Avatar
Originally Posted by Andy@QTP
Pete,
Give us a call when you get a chance. 201-444-0998
Take Care,
Andy, tried to call you about 5 minutes ago but I am thinking you guys are probably closed for the day. I should get done with work earlier tomorrow, so I will try again.
Old Aug 4, 2008 | 05:32 PM
Omec's Avatar
hmmm my Kooks dont hit anything .
Old Aug 4, 2008 | 07:24 PM
NateLS1's Avatar
I used a BFH and a long pry bar to bend the flat part the crossmember, although mine never was as close as yours. this is with new QTP's.
Old Aug 4, 2008 | 07:29 PM
Sammyboy's Avatar
I just installed my qtp's and I have the same fitting issue. I tried calling today and was put on hold for about 15min (which I eventually hug up). Could someone please pm me about this.
Old Aug 4, 2008 | 07:44 PM
primer84z's Avatar
maybe a bad batch got out...
Old Aug 4, 2008 | 09:08 PM
Full-Force's Avatar
Impossible to have a bad batch if they paid regular price. I thought you guys knew, you get what you pay for.
Old Aug 4, 2008 | 09:17 PM
07gsxr750's Avatar
I just installed my qtp's back in June with ZERO problems, stock motor mounts at 95k and almost no y pipe hitting, headers dont touch anything! When I installed them they slipped right in, especially the pass side. love these headers.
Old Aug 4, 2008 | 10:06 PM
caviness's Avatar
mine hit the same place,installed over year ago,just heated it with torch took hammer dented in k member a little easy fix didnt have to grind anything.
Old Aug 5, 2008 | 04:55 AM
White.Lightning's Avatar
I have QTP's and poly motor mounts. My one tube hits the Kmember too. I'll try notching it and see what happens.
Old Aug 6, 2008 | 06:44 AM
I have had no luck contacting QTP by phone. I tried twice on Monday and 3 times on Tuesday. All that happens is the phone rings and rings, nobody answers and apparently they dont have voicemail.
I am going to try again today, but this is the last straw. If I can't get a hold of them today I am selling and going with another brand.
Old Sep 12, 2009 | 06:20 AM
RawDawg's Avatar
I'm having the same issue with their headers and Y-pipe. Has this ever been resolved? Did QTP ever get in contact with you?
Old Sep 12, 2009 | 03:09 PM
  #32
03Sssnake's Avatar
I am sorry to hear this guys. I just removed my QTPs due to the driver side collector leaking horribly where the primaries are welded in (not completely welded on QTPs) and contact with the frame that drove me nuts. I also had their shitty ******* y-pipe and after a year of living with their ******* headers, I just bit the bullet and bought/installed ARH headers and y-pipe. Easiest header and y-pipe install with zero fitment issues. I really wished I had gone the ARH route the 1st time around, it would have saved time and money. I know this doesn't really help those that already have the QTP headers, however I hope it dissuades someone else from buying QTPs. Their customer service sucks donkey ***** to boot, way to stand behind your products ********. Good luck gentlemen, hope you are able to resolve your issues.
Old Sep 12, 2009 | 05:51 PM
  #33
xricer's Avatar
hmm reading all this makes me want to buy an aftermarket K-member along with whatever headers I eventually get, has anybody installed one on their car? Is it worth it? I'd like to make my car as light as possible and with an aftermarket k you wont have any clearence issues no matter what brand headers you go with right?
Old Sep 12, 2009 | 10:45 PM
  #34
ajsfirehawk's Avatar
Same problem, passenger side, did the poly motor mount. That worked for about 6 months, then started again. Ended up removing the header, and dimpling that tube about 200 thousands.
Old Sep 13, 2009 | 08:08 AM
  #35
ls2 bait's Avatar
the quality control at qtp is less then desirable imo. some of the headers fit great. i have installed a few sets. mine rub the steering knuckle and the pass side k member. as well as hang very low on the driver side. stainless moves a lot when it gets welded is all i can think of but still its a little ridiculous to me as most other vendors and produce consistant results with fitment.
Old Sep 13, 2009 | 02:01 PM
  #36
mike m's Avatar
I have qtp headers and y pipe on my 2001 SS it has only 54,000 miles never been wrecked and has had subframes in for a long time. Has the original mounts. Mine dropped right in and I have plenty of clearance. ( I can fit my fingers between the pipe and k frame) My car has lowering springs and I have a good amount of ground clearance. Ill try n post some pics, maybe itll help.
Old Sep 13, 2009 | 02:28 PM
  #37
xricer's Avatar
can somebody answer this?
Old Sep 13, 2009 | 04:08 PM
  #38
metalmechanic's Avatar
mine either, but i also have solid engine mounts
Old Sep 14, 2009 | 09:55 AM
  #39
ynkssws6's Avatar
I have the same problem with my qtp's. Laying on the K member "meat" and hitting the steering shaft. gay.
Old Sep 14, 2009 | 01:51 PM
  #40
98TAjwh's Avatar
an aftermarket k member would shed in the ballpark of 20-30 pounds if i remember, and it would leave a lot of room for headers.
