Downside to an underdrive pulley?
Old Aug 4, 2008 | 03:57 PM
foreverzero's Avatar
Default Downside to an underdrive pulley?
I'm sure this has been covered, but I have been searching and found nothing. I am looking to buy a 25% UDP and I was wondering if there is a downside to them, like putting a strain on engine components? Also while Im asking noob questions, do I need a different belt if I buy one?
Old Aug 4, 2008 | 04:11 PM
z28_YOU_HO's Avatar
should work on the same belt. Only downsides ive heard are dim'd lights
Old Aug 4, 2008 | 04:13 PM
Thanks for the quick reply Dimmed lights? If thats all, then Im sold. I heard that it burns out some of your components a lot quicker. Anyone dyno there car before and after a Underdrive pulley?
Old Aug 4, 2008 | 04:52 PM
WS6_00's Avatar
i bought mine and needed diff belt(s)? and have not had any dimming of the headlights. the oil temp does like to raise up when i get on it but I have heard thats normal. the underdrive pulleys don't add too much HP it's a slight difference but nothing "OMG"
Old Aug 4, 2008 | 05:00 PM
_JB_'s Avatar
No problems here.
Old Aug 4, 2008 | 05:36 PM
omcar's Avatar
I have the ASP crank pulley and to me it was worth almost a tenth.
Old Aug 4, 2008 | 05:55 PM
OEM_TA's Avatar
You will find that when idling your voltage will drop to about 8-9 vdc. This will appear as dimmer lighting, slower heat/ac fan speed and slower turn signal blinking. These symptoms will disappear as soon as you give it some gas and the rpm's get above 1000.
Now as far as premature damaging of components, here is what happens. When the voltage source for an item drops the amount of current draw increases. This will translate into higher temperatures in the wiring and the item being run. Heat will shorten the life of most anything electrical, by how much will depend on each individual item.
I have run an underdrive pulley for over 120K miles. So far, I still have the original alternator, dash lights, headlight motors, heater fan. Only electrical items I have had to change are window motors (no surprise here), headlights (they all go eventually) and the ignition switch (now this one i suspect as possibly being due to the lower voltage).
I say this because the plastic near all the terminals was melted and the contacts were pitted. Now to be fair there was 142K miles on the switch and it may have just gotten old. But being an electronics person it did look to me like a high current draw type damage. It was an easy fix and cheap too.
Dyno test showed an 8 HP gain, it was the first modification done to the car.
Old Aug 4, 2008 | 06:04 PM
qdz21's Avatar
Wow, Nice explaination!!
I have an ASP crank and need different belts!!
Old Aug 4, 2008 | 06:39 PM
gnasty1521's Avatar
Nice work explaining that. I am actually an electrician and I couldn't have put it better myself, good work!
Old Aug 4, 2008 | 06:45 PM
OEM_TA's Avatar
Thanks I do get lucky now & then.
I guess I did not forget everything I learned college ....way back in the dark ages of the mid-70's.
Old Aug 4, 2008 | 06:49 PM
gnasty1521's Avatar
I aint got college but I do have 5 years OJT on helicopters (Afghanistan and the like). Not to mention everybodys cars that have elec problems. Good to know I ain't the only one who thought it was a good thing to have around cars. Dont know anything about a cam but put a wiring diagram there and I do alright...
Old Aug 4, 2008 | 06:52 PM
transamblack's Avatar
Great thread, I'm looking into an ASP Pulley myself. What belt will I need when I get this?
Old Aug 4, 2008 | 07:05 PM
LS1 Freak's Avatar
^^^ I bought both belts when I got my ASP installed( Gates) you can get'em anywhere, I hope this helps
Old Aug 4, 2008 | 07:09 PM
qdz21's Avatar
Belts #'s are 760k6 and 378k4. Got them from Advance Auto Parts
Old Aug 4, 2008 | 07:34 PM
Randy WS6's Avatar
You can get a over drive pulley for the alternator to help with low rpm voltage drop. This is from Thunder Racing >>>>>>>>>>>>>>>>>>>>>>
Overdrive Alternator Pulley - Recommended for automatic cars to help bring alternator speeds back to near stock levels without sacrificing too much horsepower. Extremely important for vehicles with high accessory drag such as cars with lots of stereo modifications.
Underdrive Alternator Pulley - Recommended mainly for track use. Not recommended for daily street use due to low alternator charging.
Alt PulleyPulley Part #AC Belt #Access. Belt #
Overdrive49-54012011-378K411-755K6
Underdrive49-54008411-378K411-770K6Stock -11-378K411-760K6
Old Aug 4, 2008 | 08:03 PM
7camaro7's Avatar
Nobody's mentioned this one yet. With an automatic ONLY, you will need the overdrive alternater pulley. Only with the automatics do little annoyances arise such as dimming headlights and that type thing. If you've got a 6spd as I do, then you won't need the overdrive pulley for the alt and your electronics will be just fine. My underdrive pulley only added to my lack of traction. I just bought another "fix traction issues" mod recently though I should be able to put my full bolt on power down on the track nicely now
Old Aug 4, 2008 | 08:18 PM
Wow, I didnt expect to get this much info out of this thread! not bad, 8 hp for a pulley
Old Aug 4, 2008 | 09:24 PM
c0ncEpT's Avatar
Well I was going to get one at one point. But my friend took his turbo car out on its maiden voyage to the track and every pass was getting faster and faster till he got it to a 12.0 and than the car died in the staging lanes. It had a dead battery. He switched back to the stock pulley and never had a problem sense. Thats the sole reason I wont get one is because when I'm shooting for 11's I know its gonna come back and **** me
Old Aug 4, 2008 | 09:27 PM
Superman09's Avatar
LS1Tech Sponsor
yea that was me, first passes with old kit on stock motor with 5 psi. i was very pissed, so close! However, to put the puzzle together, i had my lights on, all guages inside had lights, car was sitting in 3rd as i was up next, had a scavenge pump running, etc. So all accessories plus more were running so having the underdrive pulley didnt not supply enough at the time and killed it.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Aug 4, 2008 | 10:58 PM
was it a 10% or a 25%? or does it really matter? I just saw an 80% one on ebay for 90 bucks, but im sure its overkill
