underhood temp question re: coated long tubes
Old Aug 15, 2008 | 07:30 AM
omcar's Avatar
Default underhood temp question re: coated long tubes
crazy question but when you changed from stock exhaust manifolds to coated long tube headers did you notice if your underhood heat/temp went up or down? Thanks
Old Aug 15, 2008 | 11:53 AM
omcar's Avatar
Has anyone experienced a change in under hood temperature after installing long tubes?
Old Aug 15, 2008 | 11:55 AM
954mula's Avatar
No way temp would go up. Stock manifolds just cannot dissipate heat that well.
Old Aug 15, 2008 | 03:28 PM
omcar's Avatar
Thanks I was hoping for that..
Old Aug 15, 2008 | 05:35 PM
Sicko's Avatar
Honestly on my GTO the temps went up. Then again us Gtos have heat soak problems.
Old Aug 15, 2008 | 05:39 PM
RooRnZ28's Avatar
mine seemed to go up as well when i threw on some Jet Hot LT's... i guess those factory heat shields work pretty good!
Old Aug 15, 2008 | 11:52 PM
SOMbitch's Avatar
Hell yeah it goes up. PART of why I am putting a bigger radiator on tomorrow night after work.
Old Aug 15, 2008 | 11:59 PM
CranMaro99's Avatar
They go up for sure.
Old Aug 16, 2008 | 06:57 AM
omcar's Avatar
Wow..so the under hood temps do go up with long tubes..does it matter if they are stainless or coated? I can't afford hotter under hood temps as I bracket race and as you go rounds there is less and less time to cool... it's a problem.
Old Aug 16, 2008 | 01:28 PM
SSmoken's Avatar
I could tell a temp change just by lifting the hood.
Old Aug 16, 2008 | 01:36 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Stainless headers here (not coated), and the temps went up noticeably, but never measured the difference.
Old Aug 16, 2008 | 01:38 PM
formulajunky's Avatar
yeah i have mid lengths and I noticed a temp increase.
