the evil tick
Old Aug 18, 2008 | 02:04 PM
wtomlinson's Avatar
Default the evil tick
ok so last week i started hearing this ticking sound while my car was idling, and it was at the same time i had my o2 sensors go out on me (2nd time in 6 months). the ticking would progress as the engine rmps went up. now this sounds like 2 things: either an exhaust leak or something internal.
i had my car on stands the other day replacing the o2 sensors, and i started it up, then crawled under there to see if i could pinpoint where it was. i checked the clamps on the collectors: good. checked the merge, good. checked all fluids, cuz it sounds almost like coming from trans, all good. any ideas on this?
http://s304.photobucket.com/albums/n...t=DSCF1274.flv
Old Aug 18, 2008 | 06:26 PM
wtomlinson's Avatar
forgot to mention that right after i changed the sensors, it got a lot quiter for about an hour, then it came back.
Old Aug 18, 2008 | 11:51 PM
blades11b's Avatar
hard so say without being there to hear it for my self but i would say it doesnt sound mechanical, sounds almost like one Cylinder isnt firing but like i said hard to say not being there... which also tie it into your O2 sensors going out.
Old Aug 24, 2008 | 11:20 PM
wtomlinson's Avatar
ok so i crawled under there after replacing both o2 sensors with bosch 13111s, and i (think) i pinpointed it to the driver's side, but unsure. was about a quart low on oil, replaced the fluid, and still hearing it.
Old Aug 25, 2008 | 02:48 PM
00_transam_vert's Avatar
Its a long shot, but check your converter bolts. They are usually waaay more noisey but its somwhere to start! Good Luck!
Old Aug 25, 2008 | 11:27 PM
Omec's Avatar
how many miles on it? possibly a lifter(s) that arent pumping up?
