Trouble shooting after F.A.S.T 92/92
I have installed my combo, and took it out for a test drive. When i started the car it idled about 400 rpm above usual which i wasnt to concerned about. Adjusted the blade screw and got it taken care of.
Left my house and began the drive, when i accelerate and then let off of the gas, the car will stay at whatever RPMs i clutched it at for about 5 seconds before it returns to normal. Also when i take the car out of gear coming to a stop it stays at rpm and then increases slightly before coming back down. OR sometimes it doesnt come back down so i have to Clutch/Brake it (almost kill the car) to get it back to idle rpm.
Also when i turn the A/C on or off at idle it raises the rpm to almost 2000 for about 3 seconds and then returns to normal.
I have checked all of my connections and hoses, from what i can tell i havent missed anything.
Any help is greatly appreciated.
And before i get my ***** busted, i tried about 10 searches and only came up with one post which was of no use to my problem.
Thanks for all the help, i did a "re learn idle" and the 5 minute idle / 5 minute idle with ac on. it now only idle surges with the ac on, but no where near as bad as it was, therefore i think ill just roll with the windows down until i can afford hp tuners and tune out the problem.
